1 or 2 coats? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-23-2010, 04:09 PM Thread Starter
1 or 2 coats?
Do you have to apply one or 2 coats of this stuff? It doesn't say, Por 15 requires two coats, so I'd think this would be the same, but it doesn't say. Maybe I'll luck out and only have to apply one coat Will one gallon be enough to cover frame,oil pan, axles, leaf springs, bottom of the box, up the sides by the fuel cap, ect. I want to lay under the truck and see EVERYTHING covered in this stuff
http://www.rustbullet.com/ProductCar...?idproduct=427
F-350 is offline
post #2 of 3 (permalink) Old 01-24-2010, 01:29 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
Re: 1 or 2 coats?
2 coats... its hard to over do it and you cant have to much protection. if i were you id buy two gallons cause if you only use one you could bring back the other one
Refugee
pstroke96 is offline
post #3 of 3 (permalink) Old 01-25-2010, 02:18 AM
04MT's Avatar
Re: 1 or 2 coats?
POR 15 is a single coat plus the UV protection coat. Best paint i've ever used.
EDIT:Whoops, just looked at POR-15's site and it did say minimum of 2 coats and up to 4 for underwater apps plus the UV coat...last time i'll belive what the paint guy tells me lol.
04 F-350 4X4 6.0 Auto,XCAL 3 with Gearhead tunes, ARP's, IPR GEN 2 delete, 58 volt FICM from Swamps, Performance Machine coolant filter with ELC, Blue spring mod, and a Scangauge 2 to watch everything.
04MT is offline
