Tint Glue Removal HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 12-17-2009, 02:16 AM Thread Starter
Powerstroke Addict
Nally7.3Powerstroke's Avatar
Question Tint Glue Removal HELP
Ok so I had to take the tint off my car because I got pulled over and it was way too dark, so now I am left with all the glue on the windows and its gotta go. What do you guys recommend for the easiest and best way to get all the glue off???
Nally7.3Powerstroke is offline
post #2 of 17 (permalink) Old 12-17-2009, 03:07 AM
BOOSTADDICTION
Re: Tint Glue Removal HELP
Window cleaner and a razor blade, just don't scratch your windows..
99' F250 PSD 10 lift, BTS, Cross over steering with ram assist. 4" exhaust, Needs more fuel and boost.
02' Excursion bone stock for the wife. FOR SALE $14,900
07' F350 dually with a utility bed, the work truck.
BIG99 is offline
post #3 of 17 (permalink) Old 12-17-2009, 03:09 AM
ARMY bound
works perfect
bbbxcursion is offline
post #4 of 17 (permalink) Old 12-17-2009, 04:41 PM
I use either 3M Tar and Bug remover or Good old WD40, That 3M is Some Good stuff,Be careful with that Razor!!! Keep it new and Sharp and at a Good Angle.
If you have to remove anymore tint Try heating it up with a hair drier first!
If you can get one corner started sometimes it will come off Clean Glue and all!
I had my windows tinted not long ago and there was trash between the tint and window on two of them so 5 hours after the install I removed the tint,i got one corner started and Pulled it real easy and it came off Clean....
I Know if yours has been on there for a while if will be different ,But if you heat it up first with the Hair drier You may get Lucky :~)
Good luck!
lead foot is offline
post #5 of 17 (permalink) Old 12-17-2009, 04:43 PM
OBS Strokin'
RNRacing's Avatar
thats how i do it at work for inspections
Jon
95 powerstroke 4x4 tony tuned , Jim's hybrids, intercooled by banks, oil by dieselsite, airdogII custom fuel, and all the other bs 257k miles
RUSTY NUTS RACING
RNRacing is offline
post #6 of 17 (permalink) Old 12-17-2009, 04:49 PM
Sponsor
jimdawg185's Avatar
Ammonia and a stainless razor blade, it will last longer trust me. I have tinted windows for over 10 years now, you can't beat that combo. Only exception would be rear windows with defrost lines, those require a little more skill.
2000 EX, fuel, air, and heat.
jimdawg185 is offline
post #7 of 17 (permalink) Old 12-20-2009, 05:14 AM
Straight ammonia? I believe you that it works, but I don't think I could handle the smell of it. Especially in close quarters like the inside of a vehicle.
Karl in NC
Early 1999 F250 6-speed: the DD and tow rig; DIY intake, stock exhaust straight piped
2004 Honda S2000: the autocross and sunny weather car
krshultz is offline
post #8 of 17 (permalink) Old 12-20-2009, 05:52 AM
PSD
CNDiesel's Avatar
theres a prouct called Goo Gone. Works pritty well when used with a razor blade.
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #9 of 17 (permalink) Old 12-20-2009, 05:28 PM
Zrock's Avatar
The make a product just for removing tint glue. Spray it on and take a rubber spreader and wipe off... Works great and no effort... can be found anywere that sells tint
Zrock is offline
post #10 of 17 (permalink) Old 12-20-2009, 06:32 PM
POWERSTROKEMIKE
two ways my buddy does it..
or steam an a stainless razor blade..
powerstrokemike is offline
