swirl marks and such - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-18-2009, 05:44 PM Thread Starter
Back in Black
stroken's Avatar
Hey guys, my trans is out and truck will be down for 2 weeks so i am going to do a cleaning.
I started by washing and now fine cut cleaner on the paint to bring the white back to even whiter. its working well, I used the maquires stuff, However you spell it, lol
What is the absolute best stuff to get out scratched and swirls? The owner before me owned a construction company so it has TONS of light scratches you can only see at certian angles but I would like to get out, im tired of spending 25$ on somthing and it not working so thought i would get some opinions.
Thanks
2009 F-250 ccsb black/black
Lowered 4400lb spring, 20x10 MM962, Nitto 420, traction bars, 5" exhaust 7" MBRP black stack, SCT - Innovative tunes, IDP cold side IC pipe, MPD trans. Blacked outtttt
stroken is offline
post #2 of 10 (permalink) Old 11-18-2009, 05:47 PM
Twitch
Big Monk's Avatar
Re: swirl marks and such
Adams swirl and haze remover. A long with some of their wax products..and a few passes with the buffer.
Adam's Polishes
02 F250 4x4..."Smokey"
Big Monk is offline
post #3 of 10 (permalink) Old 11-18-2009, 06:28 PM
Lovin Life...
02BigD's Avatar
Professional clay bar, then polish and wax.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #4 of 10 (permalink) Old 11-18-2009, 09:25 PM
The only way to remove scratches and swirls is to polish them out. As to what polish is best - that sort of depends on who you ask, because much like ice cream, everyone has their favorite. The stuff I use the most is made by Menzerna; if I had to pick one, it would be their Power Finish compound. You can use it with a number of different pads to achieve the level of correction that you're after.
I've used some of the Adam's products and liked them; however, I've never used any of their polishes, so I can't offer an opinion on those.
Karl in NC
Early 1999 F250 6-speed: the DD and tow rig; DIY intake, stock exhaust straight piped
2004 Honda S2000: the autocross and sunny weather car
krshultz is offline
post #5 of 10 (permalink) Old 11-19-2009, 10:12 AM Thread Starter
Back in Black
stroken's Avatar
The only thing about adams is i can find the only way to get ahold of it is order it, I havnt found anywhere that sells them.
What kind of buffer do most use? and where do you get it? i borrowed one from a buddy, but its a sander/buffer combo, very big and i cant find the right pads for it either...
stroken is offline
post #6 of 10 (permalink) Old 11-19-2009, 11:05 AM
Lovin Life...
02BigD's Avatar
Kenny, Userma3648 I believe sells Adams. PM him and see what's up. I'll be up his way tomorrow (going to Cabellas ) and I'd be happy to grab you some stuff if that is the case.
02BigD is offline
post #7 of 10 (permalink) Old 11-28-2009, 01:11 AM
Layson's Avatar
Get there orbital kit... That is what I use. It is a lot of work, but your truck will look brand new when you are done...
Layson is offline
post #8 of 10 (permalink) Old 11-28-2009, 06:26 AM
00Rich's Avatar
2008 F-250 FX4 cc,4x4
00Rich is offline
post #9 of 10 (permalink) Old 11-28-2009, 11:46 AM
PSN nerd
I use some evercoat, 3m, and adams stuff. For the scratches like your talking about I usually use 3m imperial rubbing compound with a evercoat foam compound pad. But unless you have done this alot or know someone who can teach you how to this can also destroy a paint job easily is not done right. The buffer that adams has is MUCH more forgiving than a rotory buffer. Remember too once you have used any type of rubbing compound on that pad only use it for that. Then after that I use a polish type wax, then finishing glaze and your back to new again. I do clay bar right after washing just to make sure you get all the junk out of the paint. Some detail guys think this is a wasted step, but I am afraid of having something embedded in the paint and come loose with the buffer and create you more work. This also is not as much of an issue with the orbital buffer but still is to an extent.
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #10 of 10 (permalink) Old 12-01-2009, 02:24 PM
Buy a Porter Cable 7424 and some pads. You wont be disappointed, and even an amateur would have a hard time screwing up their paint with it. Especially white.
Poorboys' Porter Cable 7424 Package
nhill2090 is offline
