What areas are prone to rust on a SD? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 10-22-2009, 09:55 PM Thread Starter
I am not sure if this is the right area to post this in, but here it goes. I am looking at buying a 02 F350 supercab long box dually. What areas should I look at to see if it has any rusting issues? The current owner said he had the bottom of both front doors redone last year, I know the owner of the body shop he took it to and they do very good work. Besides the doors are there any other areas?
Thanks
Paul
PHS79 is offline
post #2 of 27 (permalink) Old 10-22-2009, 10:17 PM
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
Re: What areas are prone to rust on a SD?
fender wells and cab corners seem to rust quite a bit.
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #3 of 27 (permalink) Old 10-22-2009, 11:30 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Oilpan! That to me is a biggie!
SMOK'N BLUE STROKER is offline
post #4 of 27 (permalink) Old 10-22-2009, 11:40 PM
Super Hauler!
Super_Hauler's Avatar
as well as the inside of the front doors on the bottom in the inside, they will start from the inside and work its way to exterior.
Super_Hauler is offline
post #5 of 27 (permalink) Old 10-22-2009, 11:52 PM
Canadian Eh
16yrenthusiest's Avatar
ya it rusts under the paint. our ex was leaking, just patched it up with some plastic steel
96 F250 7.3, auto, eclb, D60 swap, TS 6 pos, diy intake, Flo-pro turboback, ccv mod, Isspro gauges, Detroit Truetrac, 16x10 eagles, 315/75/16 Fierce Attitudes
16yrenthusiest is offline
post #6 of 27 (permalink) Old 10-22-2009, 11:56 PM
Guest
Posts: n/a
None compared to a Dodge
post #7 of 27 (permalink) Old 10-23-2009, 12:54 PM
userma3648's Avatar
and the oil pan
08 6.4 with some goodies
userma3648 is offline
post #8 of 27 (permalink) Old 10-23-2009, 03:40 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
I had the bottoms of all my doors redone, cab corners, i just noticed a small bubble around back fenderwell, these are the most common places.
Check the Oil Pan out really well as others have said.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #9 of 27 (permalink) Old 10-23-2009, 04:01 PM
me2
The first thing I do on a new truck is grab a pail of roofing tar, remove the wheels and fill the fenderwell lips until they are level with tar. That way dirt, mud and moisture can't sit there. Then I spray the inside of the fenderwells with a rustproofer and then tar them too. Result: no fenderwell rust. The fenderwells on my truck are like new, in spite of it being 10 years old.
I've never seen rust in the doors. I'll check mine the next time I have to door panels off.
me2 is offline
post #10 of 27 (permalink) Old 10-23-2009, 05:55 PM
JDG's #1 Fan
All Ford doors rust on the inside at the bottom. They rust from the inside out.
Brian
