Water spots on paint and window, what to use for removal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 11-03-2014, 01:34 PM Thread Starter
I have some hard water spots on my excursions paint and windows. What type of products can I use to remove the waterspots? Thanks for your time.
Suprsiz3_ls1 is offline
post #2 of 9 (permalink) Old 11-03-2014, 02:16 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Water spots on paint and window, what to use for removal?
i've used a clay bar kit for water spots on windows before. i don't recall using it on the paint specifically for water spots though
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 9 (permalink) Old 11-03-2014, 06:02 PM
Sabol
sabola1's Avatar
I hooked up a home sediment filter in my garage last year. We have well water. This year I also ran a bypass, or force pass, whichever way you look at it, so now I can open a valve and close another then I get softened, filtered water out my spiggot in the garage. This way I can wash my cars, camper and truck at home. I guess once you get them cleared then this may help in the future. The filter is only 30-40 bucks at Lowes, refill filter cartridge is only $10 for two.
- Adam
2011 F350 6.7 CCSB Lariat FX4 stock
2006 F250 6.0 CCSB Lariat FX4 4" lift 4" exhaust
sabola1 is offline
post #4 of 9 (permalink) Old 11-03-2014, 06:14 PM
ford_trck's Avatar
Adam's polishes, their detail spray will even remove leftover wax on plastics
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
post #5 of 9 (permalink) Old 11-05-2014, 12:17 PM Thread Starter
Thanks.
post #6 of 9 (permalink) Old 11-06-2014, 12:43 AM
Clay bar followed by Megs swirl X. That's what I use and do to remove those water sposts.
stroker11 is offline
post #7 of 9 (permalink) Old 11-06-2014, 10:36 PM
StrokinDuty's Avatar
Best option is to completely and thoroughly clean windshield with 50/50 mixture of pure water and vinegar, dry completely, clay bar with the right aggressiveness bar, clean again and dry, polish with D/A buffer with medium cut polish, orange pad, then seal with rain x or favorite paint sealant. You will have crystal clear glass that is protected.
2013 F-250 6.7 Fx4 Lariat Ultimate
Amp Research Running Boards
37x12.50x20 Nitto Trail Grapplers
20" Moto Mayhem
Led tails
Electronic bed cover
Pro Comp 6" with piggy back shocks, dual steering stabilizers, anti sway in rear
Recon Side lenses
Metal Bed cover
01 7.3 runs like a top
StrokinDuty is offline
post #8 of 9 (permalink) Old 11-07-2014, 12:49 PM
Turd-250's Avatar
i've had great luck with rainx ^^^ makes cleaning much easier!
Turd-250 is offline
post #9 of 9 (permalink) Old 11-07-2014, 02:25 PM
Agreed^^^ Sealant for paint works but doesnt bond to the glass like it does on paint, so it doesnt last as long and less bead action. Better to use job specific products
20" Moto Mayhem
Led tails
Recon Side lenses
Metal Bed cover
