cleaning degas bottle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-21-2009, 09:47 PM Thread Starter
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
How do i get all of the nasty build up out of it. Ive tried filling it with industrial cleaners to no avail.
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #2 of 5 (permalink) Old 06-21-2009, 11:17 PM
Caption This
444-4D's Avatar
Re: cleaning degas bottle
Take it off, put some sand in it and shake it.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 5 (permalink) Old 06-22-2009, 09:25 PM Thread Starter
k ill try that its been layin on the ground soaking in sum brand name industrial cleaner a guy at work gave me and it hasnt done #### hopefully the sand works.
post #4 of 5 (permalink) Old 06-24-2009, 06:43 PM
Senior Veteran Member
Centxdiesel's Avatar
Garage
I used a spray product called Purple Rush from our local Mobil 1 and bulk oil supplier.
http://ardexwax.com/uploads/Purple_Rush_V150327.pdf
Simple Green will work but not as good and it will take longer to clean. The Purple Rush cleans brake master cylinder reservoirs excellent also. Just spray in with cap on, shake a little bit, then rinse out with water. If it is the brake reservoir, spray off with brake clean afterward, then shoot it with air to dry. Both will be practically clean as new.
Centxdiesel
1997 F250 XL SC, 512HP 1019TQ,
30% nozzle Hybrids from [email protected]
Adrenaline, Beans D-66,Beans E-Fuel,Valair Ceramic-Kevlar clutch.
Awesome Tuning by: Matt: from:
Centxdiesel is offline
post #5 of 5 (permalink) Old 07-10-2009, 03:37 AM
Pea gravel works well too..
william_04_x is offline
