Window decal removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-11-2009, 10:28 PM Thread Starter
JuststrokeIT's Avatar
Send a message via MSN to JuststrokeIT
What do yall recomment to remove the window decals and the likes that they leave on the glass?
early 99 F350 Supercab longbed 4x4, Diprical gauges,GTP38R, Swamps competion fuel system with bowl delete,custom intake, 4in downpipe to 6in stacks, 200/30% hybrids from swamps, tuned by swamps, head studs.main studs, WOP cryo forged rods, ceramic coated pistons,Adrenalin HPOP,DI cam. Train horns, Ranchand front bumper DMI rear, Kumho kl71
JuststrokeIT is offline
post #2 of 10 (permalink) Old 06-11-2009, 10:31 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Re: Window decal removal
I just use a razor blade, goo gone for the crap thats left behind and clean it with windex.
SMOK'N BLUE STROKER is offline
post #3 of 10 (permalink) Old 06-11-2009, 10:33 PM
mike61's Avatar
mike61 is offline
post #4 of 10 (permalink) Old 06-11-2009, 10:44 PM
Proud Sponsor
Abrannan19's Avatar
razor blade will do it
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #5 of 10 (permalink) Old 06-11-2009, 10:46 PM Thread Starter
Must be the Goo gone that does the trick I did the rest of it event he windex and it was still there thanks Ill have go get some
post #6 of 10 (permalink) Old 06-12-2009, 03:56 AM
Pulling sled for hire
ParkerFly's Avatar
I used a razor blade. A good sharp one and it will slice it right off. You'll never know it was there.
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #7 of 10 (permalink) Old 06-12-2009, 04:14 AM
King Dingaling
TANK'S 250's Avatar
steel wool....
TANK'S 250 is offline
post #8 of 10 (permalink) Old 06-12-2009, 08:15 PM
Diesel Enthusiast
MikeDually's Avatar
razor, never let me down in the past
05 CC LB DRW
Studs, Full EGR Delete First Coast, SCT, MBRP 4" Straight, IssPros
MikeDually is offline
post #9 of 10 (permalink) Old 06-12-2009, 08:35 PM
Stroker67's Avatar
Razor blade and some rubbing alchohal
Stroker67 is offline
post #10 of 10 (permalink) Old 06-12-2009, 08:38 PM
psdmike's Avatar
Razor / WD40
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
