Clay Bar & Wax - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 05-08-2009, 01:20 PM Thread Starter
I Like Red Cows
deercreekstroker's Avatar
Send a message via MSN to deercreekstroker
Clay Bar & Wax
I am wanting to clay bar and wax my pickup for graduation pictures and was wondering if some people had some advice for doing this your first time? I know your suppose to clay bar before waxing so are you suppose to follow the curves and stuff of your pickup or hows all that work? Thanks, Lance
deercreekstroker is offline
post #2 of 31 (permalink) Old 05-08-2009, 01:38 PM
<-- it's like that
Re: Clay Bar & Wax
Usually clay bars come in a kit with some type of spray. Make sure the truck is completely clean, spray a small area, and rub the clay bar on the paint. You'll be re-moulding the clay as you apply it to the truck. Just keep rubbing the areas until the paint is clear and smooth, then move to the next section. It takes some elbow grease if you've never done it before and you have a lot of stuff in the paint.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 31 (permalink) Old 05-08-2009, 02:41 PM
Re: Clay Bar & Wax
Try this video, it will tell you everything you need to know about clay barring a truck.
http://www.youtube.com/watch?v=ZcZRj...layer_embedded
EGR Delete
H&S Mini Maxx
Sinister Coolant Filter
Cat Delete
ZooDad Mod
New6.0PSOwner is offline
post #4 of 31 (permalink) Old 05-08-2009, 02:49 PM
01platinum's Avatar
Re: Clay Bar & Wax
I just did mine and you can listen to the sound. When you start off you will think you are sanding the truck. Then after a few mins it will start to clear up and the sound will go away.
I can't believe how much crap I pulled out of the paint.
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #5 of 31 (permalink) Old 05-08-2009, 02:53 PM
black_pstroke's Avatar
Re: Clay Bar & Wax
yep just go like you normally would waxing.. after you get dont and wipe it off and run your hand down the part you just did and if it still feels a little rough hit it again. till it feels smooth.. and make sure to give yourself plenty off time if you do it good after you get a coat of wax on it it will shine like it was new.
i dont have any before and afters but here s an after pic on my 97. it made a world of difference
black_pstroke is offline
post #6 of 31 (permalink) Old 05-08-2009, 03:18 PM
Super Moderator
weweld's Avatar
Re: Clay Bar & Wax
Get the Clay Magic stuff it's the best I've tried. I order off line and use the Meguiars Quick Detailer for the spray lube and get the Clay Magic bar by it self.
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #7 of 31 (permalink) Old 05-08-2009, 03:24 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
Re: Clay Bar & Wax
Is there any step in between the clay and the wax? Do you need to wash again or anything? I have also been considering doing this to my truck.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #8 of 31 (permalink) Old 05-08-2009, 03:31 PM
Super Moderator
weweld's Avatar
Re: Clay Bar & Wax
No washing needed in between the clay and the wax unless you want to use a polish first , sometimes I do that if the paint looks a little dull and the I apply the wax
Gene
with less stuff
Builder & Driver of
Builder of
weweld is offline
post #9 of 31 (permalink) Old 05-08-2009, 03:47 PM
JDG's #1 Fan
Re: Clay Bar & Wax
What polish and wax do you use Gene? Is the only place the clay magic bars are available online?
Brian
post #10 of 31 (permalink) Old 05-08-2009, 05:17 PM
NYFB. Thats what.
jontheturboguy's Avatar
Re: Clay Bar & Wax
The best clay I have found is 3m. Use a little water and soap in a spray bottle for lubrication. Then rinse after you're done with water. Shami dry so the water doesn't leave spots.
Wax.
The end.
jontheturboguy is offline
