spraying engine - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 04-05-2009, 02:33 PM Thread Starter
unaccountably transformed
bootstrap1002's Avatar
spraying engine
if i cover filter can i spray engine?
bootstrap1002 is offline
post #2 of 29 (permalink) Old 04-05-2009, 02:59 PM
Super Hauler!
Super_Hauler's Avatar
Re: spraying engine
with a garden hose and some degreaser yes with pressure washer NO!
Super_Hauler is offline
post #3 of 29 (permalink) Old 04-05-2009, 03:05 PM
7.3
BIGBILL105 45's Avatar
Send a message via AIM to BIGBILL105 45
Re: spraying engine
We are going over detailing in school and we have been told that we can spray engines with pressure washers.
1999 F250 Super Duty 7.3 ext cab short bed xlt 4x4 offroad
5' turn out stacks, ts 6 pos chip, edge insight cs,4 inch downpipe, 5 inch straight pipe, ARP headstuds, ugly step delete, 2% tint, black lariat rims, 35 inch pro comp x terrains, 7 inch flip out dvd player, remote starter
BIGBILL105 45 is offline
post #4 of 29 (permalink) Old 04-05-2009, 04:16 PM
FordCowboy's Avatar
Re: spraying engine
Older engines I've never had trouble, but there are so many electronics and sensors and wires on these that there is a pretty high risk that a wire could be worn thin or a gasket on a sensor isn't working right or something that you might end up frying.
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #5 of 29 (permalink) Old 04-05-2009, 04:54 PM
PSN Mega Miler
crowz's Avatar
Re: spraying engine
Pressure washing seems to be a hit or miss thing. My step dad could pressure wash a power substation inside out with the power running thru it with no ill effects if he owned it.
If I had a pet rock and he pressure washed it the thing would fall apart. Every time Ive let him pressure wash a car of mine it never ran right again or took weeks to get back to normal.
Im totally against pressure washing for obvious reasons
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #6 of 29 (permalink) Old 04-05-2009, 05:24 PM
<----Colin Banks
mattymx's Avatar
Re: spraying engine
I will not put a pressure washer to my PSD's engines. Just not a good idea. Unless you like hunting for ghost electrical issues. Also if you use a degreaser, just get some simple green. Normal engine degreaser will erode the oil filler cap among other things.
mattymx is offline
post #7 of 29 (permalink) Old 04-05-2009, 05:27 PM
PSN Mega Miler
crowz's Avatar
Re: spraying engine
Must be what happened to my oil fill cap, looks like something chewed on it. Bad pitted.
crowz is offline
post #8 of 29 (permalink) Old 04-05-2009, 07:08 PM
jaybuller's Avatar
Re: spraying engine
yep dont pressure wash it, you risk blowing the insulation off the wires especially if they are old and brittle, degreaser set for bout 30 min then flush with garden hose with the trigger sprayer.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #9 of 29 (permalink) Old 04-05-2009, 07:31 PM
Re: spraying engine
I pressure wash my PSD and All of our Big rig engines a few times a year and i haven't had any problems. But i have heard of people that really mess #### up doing that so like Crowz said its kinda hit or miss just stick with simple green and a garden hose if you wanna be safe!!!
ohiopsdfordman is offline
post #10 of 29 (permalink) Old 04-07-2009, 02:32 PM
"Smoke A Lil Smoke"
chappy's Avatar
Re: spraying engine
I've power washed mine 3 times swince august and have had no problems.Getting ready to do it again to get all the oil off it.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
