rust preventing? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 03-31-2009, 03:51 PM Thread Starter
panteramatt's Avatar
rust preventing?
My paint is starting to bubble around my rear wheelwells. What can be done to prevent it front spreading further?
2000 ext cab 4x4 dp tuner, magnaflow stainless 4", woods vb, isspro gauges,tymar, kenwood dvd, 6" lift and 37's. SOLD
2006 CCSB:SCT X4, barders stage 2 turbo, straight pipe
panteramatt is offline
post #2 of 23 (permalink) Old 03-31-2009, 05:52 PM
Banned
Re: rust preventing?
Rust converter
Dieselhead Jake is offline
post #3 of 23 (permalink) Old 04-06-2009, 04:56 PM
throttle jockey by trade
hookin78's Avatar
I have been mixing about 2 parts kerosene, to 1 part (about) new wheel bearing grease ( its a pain to mix, let set for a day or two stir occasionally), and seems to workd very well, the kerosene drys out and all you have left is a layer of bearing grease, been using it for years, I actually stopped the rust in the rear fender wells. You can use a spray bottle to spray it on , I use a Westleys Beach White bottle.
Just a thought
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #4 of 23 (permalink) Old 04-06-2009, 06:24 PM Thread Starter
But the rust is coming through the paint on the outside. Dont think grease on the outside of my truck would look too good.
post #5 of 23 (permalink) Old 04-06-2009, 06:25 PM Thread Starter
Whats a good way to fix the bubbling?
post #6 of 23 (permalink) Old 04-06-2009, 07:41 PM
hookin78's Avatar
Patch panels , BONDO, new bed side, new bed, many options, these trucks have a black foam type stuff between the bedside and the inner fenderwell and if it gets soaked with salty road grime stuff, it will rust, no matter how good you take care of your truck, your best bet is to fix the bubbles by the manner of your choice and then soak the foam with something that will prevent it from rusting.
hookin78 is offline
post #7 of 23 (permalink) Old 04-07-2009, 12:34 AM
Lovin Life...
02BigD's Avatar
I had the same exact problem last year. We stripped to bare metal, little filler to smooth out, primer and paint. Sprayed the inner well with the sealer suggested above.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #8 of 23 (permalink) Old 04-07-2009, 12:43 AM Thread Starter
Did you guys use automotive primer and paint?
post #9 of 23 (permalink) Old 04-07-2009, 12:57 AM
hookin78's Avatar
I used finger paint.........Just kiddin, Yes , I use automotive type materials and I like the epoxy primer that has a real good sealer in it.
hookin78 is offline
post #10 of 23 (permalink) Old 04-07-2009, 01:14 AM Thread Starter
Well I want to grind it down, bondo it, and primer. Then Im gonna cover it with flares. Any good rattlecan primer?
