wet sanding - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 03-24-2009, 03:38 PM Thread Starter
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
wet sanding
so what is the proper way to Wet Sand my truck to get light scratches and scuff marks out of the paint.
what grit paper? and tricks? what to watch out for so I don't go through?
thanks
DieselPower1966
John
DieselPower1966 is offline
post #2 of 17 (permalink) Old 03-24-2009, 04:56 PM
Send a message via AIM to JohnT
Re: wet sanding
Wet sanding is not hard if you have watched someone do it before. Its a bit hard to explain on the interweb but I will attempt to.
You will need, 1000grit wet/dry sand paper, 2000grit wet/dry sandpaper, sanding block, rubbing compound(I have been using Meguiars #1 and #9), and wax to finish.
Get a bucket, and put some soapy water in it. Take your 1000grit and 2000grit sandpaper and sanding block and throw it in there also. Its not going to hurt it. Next find your scratch and lightly sand it with the 1000grit and the block being sure to keep the sandpaper wet. Go in straight lines not in circular motions. Go a few times up and down, then a few times left and right. Next step up to the 2000grit, do the same procedure. Make sure the sandpaper stays wet while doing this. Next buff the area with the Medium Cut compound(Meguiars #1 is what I use), then proceed after wards with Swirl remover. After the use of the swirl remover if you still see the scratch, back to wet sanding it a bit more. Its a time consuming process but you don't want to go too far taking clear off to get the scuff out. Its much better to take your time. The more experience you get wetsanding, the easier it is to judge how long to sand before stopping. If you truly want to be super careful, you can skip using the 1000grit and use just 2000grit. It may look scary after you first get done sanding but when you slowly start to use different abrasives on the surface it will clean up.
If the light scratchs are very light, you can probably get away with just the polish. Just remember to start slow, don't get too carried away too fast because it does not take long to mess up your paint.
Hope this isn't to hard to understand.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #3 of 17 (permalink) Old 03-24-2009, 05:15 PM Thread Starter
Re: wet sanding
JohnT
excellent instructions, I will try it, in an inconspicuous place,
btw,
my name is also John, last initial T. that's weird.
DieselPower1966
John
post #4 of 17 (permalink) Old 03-24-2009, 09:49 PM
Thomas7.3psd's Avatar
Re: wet sanding
Thats good stuff. Thanks
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #5 of 17 (permalink) Old 03-24-2009, 10:11 PM
brandon
bcangelo's Avatar
Re: wet sanding
i have painted a few cars and touched up many and i would have to say that these will provide good results
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #6 of 17 (permalink) Old 03-24-2009, 10:18 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: wet sanding
Great info.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #7 of 17 (permalink) Old 03-24-2009, 11:09 PM
Big Sky Groomer Op.
ford7.3sd's Avatar
Re: wet sanding
i was wondering the same as the OP.
great info
Go Army!
Tyler-
2001 F-350SD XLT SC,LB 4X4.
DIY intake, Tuned by deoblo
,gauges(boost,trans,piro), 5 inch MBRP,4 inch superlift and 37 inch ss m16s and sportin the 05 headlights.
E-99 F-250SD lariat SC,SB 4X4.
lots of dents a plow, in need of some love.
95 Chubby Blazer 4X4... pile.
ford7.3sd is offline
post #8 of 17 (permalink) Old 03-25-2009, 02:36 AM
That thing got a Cummins?
nasty96's Avatar
Re: wet sanding
Just to add to what JohT said check the paper often to make sure it doesn't clog up, and DO NOT sand or buff on sharp edges. You will go right thru the clearcoat
Ford makes it
, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
nasty96 is offline
post #9 of 17 (permalink) Old 03-25-2009, 03:56 AM
Re: wet sanding
for sure. You can cause damage fast on edges.
If I have time this weekend I can do a small write up with pictures of how it works on my car. I had a small accident with my 4 wheeler and put a scuff/light scratches into the clear that need to be addressed so I can attempt a write up.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #10 of 17 (permalink) Old 03-25-2009, 06:24 AM
"Smoke A Lil Smoke"
chappy's Avatar
Re: wet sanding
Thats pretty good info.Since mine has lots of scratchs,I might try it out .Will that get rid of the orange peel also from the factory?I wanted to take the 4x4 sticker off but was worried about how nice and red it will be under there compared to the 11 year old paint.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
