Inside window cleaner - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 03-09-2009, 04:06 AM Thread Starter
Pulling sled for hire
ParkerFly's Avatar
The inside of my front window has the dreaded film on it and for some reason it's gotten worse recently, and I can't get rid of it. I've tried every kind of glass cleaner I can find but nothing works. Does anyone know something that will work? I'm O.C.D. about it.. Thanks,
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #2 of 14 (permalink) Old 03-09-2009, 04:18 AM
psdmike's Avatar
Re: Inside window cleaner
I use a foam glass cleaner from costco, i think its called "sprayaway". I'll have to look tomarrow. dont know if you can get it anywere else.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #3 of 14 (permalink) Old 03-16-2009, 09:02 PM
Fro_911's Avatar
I've cleaned alot of windows using a Windex/Muriatic acid mix... and damn does it make windows look good! I'd never do it on my truck though... the closest thing I've found with the same results as the "Muri Mix" is a cleaner called Invisible Glass. It doesn't have any detergents in it, so no chance of hazing.
Early '99 F-350 CC 4x4
"Nobody hates you more than your own reflection" - Atmosphere
Fro_911 is offline
post #4 of 14 (permalink) Old 03-16-2009, 11:47 PM
PSN Mega Miler
crowz's Avatar
Zep window cleaner
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #5 of 14 (permalink) Old 03-16-2009, 11:59 PM Thread Starter
ParkerFly's Avatar
The Zep stuff sounds good...I'm gonna pick some of that up and see what it does. Thanks crowz,
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
post #6 of 14 (permalink) Old 03-17-2009, 12:07 AM
psdmike's Avatar
Ya its called "SPRAYWAY" its a foam window cleaner.
psdmike is offline
post #7 of 14 (permalink) Old 03-17-2009, 12:19 AM
Dairy Mechanic
Magnum PD's Avatar
Ask Mark Martin. He had INSIDE windsheild wipers when he ran the Viagra car!
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
Magnum PD is offline
post #8 of 14 (permalink) Old 03-17-2009, 02:02 AM
PSN Mega Miler
crowz's Avatar
Zeps the only thing Ive found to remove oak tree sap. Thats some nasty stuff when its sets up on a windshield. Spray on and wipe it off with little or no effort. Its hard to get at retail stores but it can be ordered from the net. Theres a local guy that delivers the stuff to my biz.
crowz is offline
post #9 of 14 (permalink) Old 03-18-2009, 05:08 AM
Wannabe
Invisible Glass is the stuff!
2001 F250 CrewCab mild mods
TxFire is offline
post #10 of 14 (permalink) Old 03-20-2009, 08:59 PM
OEM Moderator
Tom S's Avatar
I also like the Zep stuff or Invisible Glass.
Tom
Tom S is offline
