TEFLON COATED STACKS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 01-23-2009, 06:48 AM Thread Starter
1TONPSD's Avatar
i know this ain't a detailing post but i need help finding a place that will Teflon coat a set of 36" stacks that are 6" dia. or if anybody knows where i can buy a stack kit that is already coated???
99 F350 reg cab
238/80 inj.
diesel site CPRx fuel system
High pressure crossover
TN ball bearing charger
ARP studs
AFE stage 2 intake
DP tuner F5
4" down pipe
5" miter cut stacks
PI convertor,bullydog shift kit, deep pan
modded 17* by terminator
1TONPSD is offline
post #2 of 17 (permalink) Old 01-23-2009, 05:36 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: TEFLON COATED STACKS
I believe ITP does, you would have to give Dennis a call to see
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #3 of 17 (permalink) Old 01-23-2009, 09:19 PM
squeak12's Avatar
Last time I checked, ITP didn't do it anymore. He can tell you who coats them for him though.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #4 of 17 (permalink) Old 01-24-2009, 12:40 AM
The Original
BigStroker's Avatar
Any special reason for the teflon coating?
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #5 of 17 (permalink) Old 01-27-2009, 03:15 AM
motoxracer42's Avatar
it can withstand the heat that comes off of the exhaust. powerdercoating is only baked on at around 400 degrees and i tends to change color when it gets to hot.
06 crew cab
06 reg cab
motoxracer42 is offline
post #6 of 17 (permalink) Old 01-27-2009, 03:30 AM
Now you can cook eggs on em with out the stick...
I need a stack
bigjake0524 is offline
post #7 of 17 (permalink) Old 01-27-2009, 04:23 AM
OBS junkie
Cat_Rebel's Avatar
What do you recommend for people that want black stacks?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 17 (permalink) Old 01-27-2009, 10:45 AM
kinda hot in these rhinos
upinsmoke70's Avatar
Send a message via AIM to upinsmoke70
It doesnt need to be teflon...
they have high temp powder coating which is good up to 1000 degrees...much better then the normal 300 degree limit on normal powder coat. If your stacks get hotter than that...i dont wanna know how hot your truck is.
Powder coating is much cheaper then teflon coating.
Look here under their warranty part for more info
http://www.eastcoastpowdercoating.co...nformation.htm
Just as a side note...these guys have charged me a few months ago about 110$ for the high temp stuff to coat a 6" stack...dunno if that was a good price or not...but with the money you can save on buying a stack that is unfinished steel...i didnt think it was bad.
upinsmoke70 is offline
post #9 of 17 (permalink) Old 01-27-2009, 02:13 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
These guys got some http://www.deepsouthdiesel.com/servl...cks/Categories You can ask bigcountry250 how he likes his single 8" its been on for a little while so he can tell ya how its holding up.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #10 of 17 (permalink) Old 01-28-2009, 01:47 PM
WV Smoker
P714's Avatar
When I wanted to switch to a black stack I just bought a piece of 6" plain exhaust pipe cut the top and painted it with flat black woodstove paint. It's worked great for a year now. No color change, bubbling or flaking.
early '99 F-350 reg. cab 6-speed 106,000 miles
P714 is offline
