Need Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-12-2009, 03:29 PM Thread Starter
Rollin' Coal
despain85's Avatar
Need Help
I pulled off my powerstoke badges and it left a little bit of adhesive still on the truck. I could get most of it off but some of it is still on there. I'm not sure what to use to get it off.
despain85 is offline
post #2 of 6 (permalink) Old 01-12-2009, 07:19 PM
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
Re: Need Help
spray some wd-40 on a rag and gently rub it away,
then wash the wd off the truck.
that always works and will not hurt the paint
DieselPower1966
John
DieselPower1966 is offline
post #3 of 6 (permalink) Old 01-12-2009, 07:48 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
Re: Need Help
When I took mine off, i just got the big stuff off, then used Mequires Cleaner Wax and a sock and just rubbed over it till it all came off.
Goo Gone Also works well.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #4 of 6 (permalink) Old 01-12-2009, 09:54 PM
Peon Extraordinaire
Re: Need Help
Goo-b-gone is good stuff. When I had my bronco, I had to use that on the interior before I put the sound deadening on... Works great.
Sam
genie144 is offline
post #5 of 6 (permalink) Old 01-14-2009, 03:28 PM
Re: Need Help
so, did you get the glue off?
which method did you used?
DieselPower1966
John
post #6 of 6 (permalink) Old 01-16-2009, 06:09 PM Thread Starter
Rollin' Coal
despain85's Avatar
Re: Need Help
Haven't had time with the weather. It's been to damn cold to do anything outside. I will do it when it warms up a bit, plus when the truck is dirty you can't even tell it's on there. Thanks for the tips!!
