Metal shavings on paint - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-28-2013, 03:14 PM Thread Starter
I cut the bumper mounts off of my truck with a grinder a few months ago and didn't think about the metals shavings on the paint. Now there are small little rust spots on top the paint I need to remove. My only thought is to clay bar the paint. Any ideas?
1997 cc lb 4x4 5 speed tymar 4 inch diamond eye straight pipe, 20 inch Eagle Alloy polished wheels,power hungry 6 pos tuned for stage 1's,idm mod,8000k H.I.D's. 4'' icon front super duty springs with sky 5'' rsk. rear 6'' icons for super duty. bilstien shocks. ebay special grill.
cams-76 is offline
post #2 of 4 (permalink) Old 04-28-2013, 03:17 PM
Administrator
Zmann's Avatar
Re: Metal shavings on paint
they likely burned in
I have ruined sunglasses and watches doing the same
I have seen windshield and storefront glass with the metal embedded in it also
not sure how to safely dislodge it from paint?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 4 (permalink) Old 05-08-2013, 10:25 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Wet sanding... Clay bar might get it, they normally melt into the clear.
It happens all the time on the commercial jobs, Glazier puts the windows in, and for some reason someone does some grinding in the general location, and were replacing windows.
Joe
CSIPSD is offline
post #4 of 4 (permalink) Old 09-18-2013, 02:10 AM
JJozwiak's Avatar
There is no way of getting it out, sorry to tell ya. You have strip your paint and repaint. The problem here comes with you don't know how far down the chip melted. It can go all the way threw the primer.
A few solutions to this: this one is labor intensive and has to be done a lot.
You have to use buffing compound and buff your paint, and not with a orbital da waxing buffer a variable speed grinder outfitted with a buffing wheel like wool or foam pad, that will get rid of the rust on the metal shavings then you need to wax the surface to cover the bare metal so it doesnt rust. As long as you keep up on wax you will be able to keep the rust away but if you see the rust come back you have to start all over again with buffing and then wax again.
Another option is buff your paint then wet sand with 1000 grit to prep your paint for another coat of clear. then spray two more coats of clear on it. I have seen people do this with mixed results. You have a 50 50 shot of the clear bubbling because of the oxidation of the metal underneath, but you will not have to wax if it is successful.
good luck
JJozwiak is offline
