best way to get dirt stains from seats? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-12-2013, 03:49 AM Thread Starter
kx450f's Avatar
well i have 05 crew cab with gray cloth interior and if you even think of a stain it apperas. even water drops make it lookes stained. ive tryed alot off diff. cleaners make it look like it does the job then u sit in the seat a couple times and they all come back. how do i get them clean? get all dirt out?
2005 f350 ,4+4, 65mm turbo, ported heads, ARP studs, egr delete, tuned FICM, custom SCT tunes, stage 1 injectors, ame intake, updated fuel spring,and rev x dont hurt, 180,000 miles
kx450f is offline
post #2 of 5 (permalink) Old 03-12-2013, 03:58 AM
Re: best way to get dirt stains from seats?
I have always used tough stuff in the yellow and red can with the scrub. Simple and has always worked for me. If it come down to it just have someone clean the seats at a detailer with a steam cleaner.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 5 (permalink) Old 03-16-2013, 06:56 PM
diesel addict
redneck6.0's Avatar
Steam cleaning is the best I.have found
2006 6.0 ccsb
1997 5.9 ecsb
redneck6.0 is offline
post #4 of 5 (permalink) Old 06-08-2013, 10:32 PM
chrgd2000's Avatar
Stains are probably set into the foam. Best way is to get it wet, put a vacuum over the stain and blow air with an air compressor from the underside. The more pressure and suction the better.
B&C Supply Co.-Automotive Reconditioning Products
chrgd2000 is offline
post #5 of 5 (permalink) Old 06-09-2013, 04:33 PM
Take the covers off the seats. Put them in a washing machine and wash them. Let them air dry for several days then treat them with Scotch Guard! Reinstall them and it will be as new!
Foxman
foxman is offline
