Waxing with a variable speed buffer? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-26-2008, 12:30 AM Thread Starter
I heard that a variable spped buffer can be a really good choice if you know what your doing. What's the trick to getting it right? I have a Makita variable speed 7". I think it goes from 600-2500rpm.
Is a random orbital better?
2001 Excursion Limited, Swamps 175/146 singles, John Wood tranny, UltraLite Gauges, 4" turbo back, AFE stage 1, Dp tunes, 7" Superlift, Fox Shocks, Firestone Airbags, 35"Toyo M/t...blah,blah,blah
SmokeWagon is offline
post #2 of 11 (permalink) Old 09-26-2008, 02:10 AM
bigd4me2's Avatar
Re: Waxing with a variable speed buffer?
negitive, no buffer for wax!
orbital=o.k.
it does not do anything you cannot do by hand though. i don't own one, but i do own a buffer!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 11 (permalink) Old 09-26-2008, 03:19 AM
OEM Moderator
Tom S's Avatar
I have been thinking a little about getting an orbital for waxing.
Tom
Tom S is offline
post #4 of 11 (permalink) Old 09-26-2008, 09:08 AM
PSN Mega Miler
crowz's Avatar
Id love to get a good buffer if I knew how to use one. Ive seen so many paint jobs ruined by people that didnt know what they were doing. Which would be me if I tried it
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #5 of 11 (permalink) Old 09-26-2008, 12:33 PM
PSN nerd
both can be used for waxing the random orbital is much much more forgiving than a rotoray buffer will be, i would definately get a variable speed if you got a buffer so you can turn the speed down and slow down but you still gotta be careful with it.
if your gonna get a orbital that porter cable is great and adams has the big pad kit for it which makes it even better!! also i think adam has a video on the buffing/polishing i dont know if it covers both buffers but i imagine it will have some great info in it.
ive got one of the porter cable orbitals and a milwaukee varible speed polisher and there both real nice
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #6 of 11 (permalink) Old 09-27-2008, 04:28 AM
bigd4me2's Avatar
I honestly can't imagine using a "buffer" for waxing. compounding and polishing, yes. but never in 25 years have i seen someone use a buffer with wax. buffers will make swirls with wax.
If you must use a buffer, please use a foam pad, and foam pad glaze. and go off all edges, not onto edges with the direction of the wheel.
bigd4me2 is offline
post #7 of 11 (permalink) Old 09-30-2008, 04:09 PM
The Porter Cable is great for removing swirls, polishing, and waxing...the waxing process is a snap when using a random orbital machine. With a random orbital once you apply a little pressure (which is fine) the pad will actually slow to a vibration with little or no spin. Even if it was spinning fast there is no chance to burn the paint. Bigd4me2 is right Foam Pads are the best way to go, they are soft and they work!
post #8 of 11 (permalink) Old 09-30-2008, 05:31 PM
PSN Mega Miler
crowz's Avatar
Might have to work up the guts to try buffing.
crowz is offline
post #9 of 11 (permalink) Old 10-10-2008, 03:01 PM
MudSouth's Avatar
I also read somewhere that you can get the real small foam pads for the Porter Cable to use in small areas like mirrors, corners, around lights, etc.
2010 6.4 LB CC 4x4
ROLL TIDE!
MudSouth is offline
post #10 of 11 (permalink) Old 12-31-2008, 03:14 AM
OEM Moderator
Tom S's Avatar
Score, I got the Porter Cable and the pads as a Xmas gift from the GF.
Tom
Tom S is offline
