what to use for filler?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 08-24-2008, 02:04 AM Thread Starter
PSN nerd
im finishing up my nerf bars on my truck and the tubing i got has some gouges in it that i wanted to get out that really shows up in the primer what are yall using to make thoose go away?? i was thinkin lightweight filler but then i gotta sand it all the way back to bare metal is there something that can be used over the primer? the gouges are really shallow i imagine just from the tubing being slid over each other its about the depth of average stamping depth...
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 2 (permalink) Old 08-28-2008, 04:11 AM
bigd4me2's Avatar
Re: what to use for filler??
you can use any body fillers over "good" cured catalyzed or epoxy primers. the key word is cured, 1 week is plenty time. but if it is spray can, i would sand it off unless its good automotive paint store self etching primer in a spray can. after you fill gouges, use the same primer over the filler. to prep for filler, just sand dry with 220, blow off dust, apply filler, sand smooth,and spray primer again.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
