2 Tone Deletion Project...Need paint help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 08-22-2008, 09:33 PM Thread Starter
ok, so i should allready know the answer to this, but does anyone know how many different variations of black there are for the 250? my truck is black with tan at the bottom, but used to be all black. i want the truck all black by houston, but dont want it looking horrible!
PMRCM#1
slowleak is offline
post #2 of 11 (permalink) Old 08-23-2008, 04:54 AM Thread Starter
Re: 2 Tone Deletion Project...Need paint help!
no one?
PMRCM#1
slowleak is offline
post #3 of 11 (permalink) Old 08-23-2008, 04:55 AM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
rhino line it
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #4 of 11 (permalink) Old 08-23-2008, 11:02 AM
urbanwheeler's Avatar
wet sanding will get rid of it, whether they took off the clear coat to put the tan on or not will be the issue, most likely they didn't and just roughed it up. or do the bedliner thing, it doesnt look bad on black trucks
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #5 of 11 (permalink) Old 08-23-2008, 02:54 PM Thread Starter
nah i dont want bedliner, i want a clean look. they took the clear off, i allready went through the layers. i just wanted to know if there was more than one shae of black that ford uses
PMRCM#1
slowleak is offline
post #6 of 11 (permalink) Old 08-23-2008, 05:51 PM
OBS junkie
Cat_Rebel's Avatar
Strip it all off & paint it yellow...you know you wantta!
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #7 of 11 (permalink) Old 08-23-2008, 05:58 PM
kinda hot in these rhinos
upinsmoke70's Avatar
Send a message via AIM to upinsmoke70
Whats wrong with a two-tone truck?
upinsmoke70 is offline
post #8 of 11 (permalink) Old 08-23-2008, 06:28 PM
find a automotive paint jobber in the phone book. Your going to want to find one that carries PPG or Diamount ( BASF ) paint. Ask them if they have a variant deck for Ford. This is a deck of sprayed out shades of black that you can hold up to your truck to find one that matches best.
Rodknocker is offline
post #9 of 11 (permalink) Old 08-23-2008, 10:59 PM
DILLIGAFF
Send a message via AIM to Redfish
the way the ford guy explained it to me is... black is one of the more expensive paint jobs, i guess there is a ton of fading that needs to be done even if you just paint a small spot.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #10 of 11 (permalink) Old 08-24-2008, 07:55 PM
bigd4me2's Avatar
like someone else suggested, go to the automotive paint store, have them look up the color code. i do not have access to that info anymore. many are straight black, no toner, some are tinted with a little color. black and white are not classified as colors.
black and white are also the cheapest for paint! are you going to do it yourself?
if your going to color sand and polish it, make sure you do basecoat/clearcoat, as it sands and buffs very easy compared to single stage. let me know if you need some advice, good luck!
p.s. you will need to sand and then prime with good catalyzed primer so the black will not show the 2 tone feather area, if you don't it will show it for sure, and will haunt you for ever!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
