OBS. fastening inside door panels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-17-2012, 02:33 AM Thread Starter
Justaworktruck
John Martens's Avatar
What do I use to refasten the inside door panels, most screws will not tighten anymore.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #2 of 4 (permalink) Old 10-22-2012, 11:47 PM
Fire junkie
Re: OBS. fastening inside door panels
Most have the plastic push pin style, along the bottom I had a few screws that would not get tight, just went with one that was just a hair bigger to get it tight
96 F250 C.C. , Rebuilt E4ODx2, open air intake, Hypermax downpipe,straight 4", Stage 1's, Autometer EGT, Boost, & Tran temp, Upgraded trannie cooler, Custom home built front & rear bumpers, head ache rack and 60 gal. Aux. fuel tank
Truck4 is offline
post #3 of 4 (permalink) Old 10-23-2012, 11:23 PM
Demon Dually
speeddemon31176's Avatar
What normally happens is that you cause the metal to bow outward around the hole which then prevents the screw from tightening. If you use a body hammer and dolly to flatten the area around the holes back out you will find that the screws will tighten back down.
speeddemon31176 is offline
post #4 of 4 (permalink) Old 10-27-2012, 10:44 PM Thread Starter
Justaworktruck
I know the OBS lower door panel screw are known to come out, I am planning to use nut rivets.
Pullinweight
