Painting my sons power wheels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-14-2012, 03:29 AM Thread Starter
06 f250 man's Avatar
I was thinking about painting my sons power wheels f150 to match my truck. I was just wondering if anyone else has done this. I never have had luck painting plastic.
2006 F250 CCSB Lariat 4*4
S&B Air Intake
EGR Delete
4" Str8 Pipe
20" XD Hoss
35.12.50.20 Mickey Thompson ATZ
Sct-ITSX Tuned by Vivian
06 f250 man is offline
post #2 of 8 (permalink) Old 08-14-2012, 03:58 AM
Juniorssrollin's Avatar
Krylon fusion and adhesion promoter will let you meet your goal
Sent from my DROID RAZR using AutoGuide.Com Free App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #3 of 8 (permalink) Old 08-14-2012, 04:02 AM
Re: Painting my sons power wheels
Glidden Gripper primer. Its the best for painting plastic. I used it on a plastic set of outdoor house shutters and its still holding up after 3 years. Its so good you can actually paint ceramic tiles after its been primed with Gripper.
Rancherousa is offline
post #4 of 8 (permalink) Old 08-14-2012, 04:18 AM Thread Starter
I appreciate the input. What's the best way to prep it. How good do I need to sand it.
S&B Air Intake
EGR Delete
4" Str8 Pipe
20" XD Hoss
post #5 of 8 (permalink) Old 08-14-2012, 07:41 PM
I just scuffed my shutters
post #6 of 8 (permalink) Old 05-04-2013, 09:59 PM
How did it come out?
Anthony Iannone is offline
post #7 of 8 (permalink) Old 05-13-2013, 06:38 PM
mandkole's Avatar
Painted a golf cart top and its similar to that blow mold plastic on the toys. Clean real good with grease remover, use the promoter per instructions and get after it with the primer, base/clear.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #8 of 8 (permalink) Old 09-18-2013, 04:18 AM
JJozwiak's Avatar
Get a DA sander with a soft foam pad and 80 grit sand paper. Sand that #### down. Then spray with a 2k build up primer surfacer. block with 600 to 800 grit paper smooth and flat. Shoot with a primer sealer then base coat and clear. This is the same process that is used on your truck, and to tell ya the truth those adhesion promoters are garbage. The automotive process is flexible too if you use dupont or ppg paints.
JJozwiak is offline
