Underhood detailing - What not to get wet? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 05-27-2012, 06:02 PM Thread Starter
Moderator
PsRumors's Avatar
When detailing under the hood what should not get wet? What's the best way to start?
I do know open element air filters. What else?
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #2 of 31 (permalink) Old 05-28-2012, 08:58 PM
08forddr's Avatar
Re: Underhood detailing - What not to get wet?
Stay away from coil packs, plug wires, and as many electrical components as you can. Other then that you are good to go.
08 CC f-250
SCT w/IDP custom tune
S&B cold air intake
20x9 hd hoss 35x12.50x20
stock height
air bags
08forddr is offline
post #3 of 31 (permalink) Old 05-28-2012, 09:03 PM
Administrator
Zmann's Avatar
I avoid High pressure and in close spraying
.. I don't want to inject water into the connectors that were just made to keep rain put
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 31 (permalink) Old 02-14-2013, 04:12 PM
blackedout7.3's Avatar
honestly, i cover major electrical connections with a plastic bag, then wet the engine down with water, spray simple green let it sit for a little, scrub any areas that a gummed up etc. and then hose it off. then take my back pack blower and blow it off the best i can and then a air pistol hooked to my air compressor to blow out any other water i missed :)
08 black and tan- egr deleted, dpf gutted(looks stock), h&s mini max, fabtech 10inch suspension lift, fuel 2 piece 20x12 nutz, 38x15.50 toyo open country mt
blackedout7.3 is offline
post #5 of 31 (permalink) Old 03-15-2013, 01:02 AM
chrgd2000's Avatar
Just did mine [IMG][/IMG][IMG][/IMG]
chrgd2000 is offline
post #6 of 31 (permalink) Old 07-27-2013, 08:06 AM
Terminator Nation
What did you use?
old man dave is offline
post #7 of 31 (permalink) Old 07-28-2013, 09:38 PM
chrgd2000's Avatar
degreaser, a little scrubbing, and a pressure washer. Hit the plastics and rubber with some detail spray after it dried.
B&C Supply Co.-Automotive Reconditioning Products
post #8 of 31 (permalink) Old 07-29-2013, 02:53 AM
STILL LEARNING
Bradbilt's Avatar
I use purple power on a WARM engine, NOT HOT. Stay away from the Alternator. let it sit about 5 min, respray if it starts to dry STAY AWAY from exterior paint(rinse off if it gets on it). Then rinse. I typically do this twice a year
Bradbilt is offline
post #9 of 31 (permalink) Old 01-22-2014, 03:07 PM
Old Yeller, REBORN
kilapapipa's Avatar
Another trick is to hit the whole engine compartment with Armor All while still wet after a cleaning unless you drive on dirt roads.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #10 of 31 (permalink) Old 02-13-2014, 11:42 AM
The main thing to remember is to only clean when the engine is completely cold. If it is hot/warm condensation can form on the inside of electrical components. I use Mean Green and spray liberally, let sit for about five minutes and spray again then rinse off with low pressure water hose. 17 years and 250,000 miles and still looks new.
okietom is offline
