Ugly Wheels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-21-2012, 03:45 AM Thread Starter
19stroker97's Avatar
Ugly Wheels
My wheels have some spots on them and i was wondering of there was any way of removing them or if theres anything to do just to make the wheels look better. I didnt buy them, they came on the truck so not sure what theyre made of. Pretty sure theyre not stock though. Any help would be appreciated. Here they are:
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #2 of 13 (permalink) Old 06-27-2012, 03:53 AM
FarmBoyStroker's Avatar
Garage
Re: Ugly Wheels
They are american racing outlaw IIs...have em on my truck...they are aluminum so id try some aluminum polish...also some people strip the clear coat off and then apply a new coat
1995
F350 XLT Powerstroke RCLB
ZF-5 Swap with South Bend Clutch
Glowshift Gauges EGT,BOOST,TRANS
3" MBRP downpipe to Single Stack
Unplugged EBPV
PHP Pheonix (Stock,Hi-Idle,DD,Perf,Tow,Race)
6637 Intake
16x8 Classic 2s
315/75r16 KM2's
"It was real and it was fun but it wasnt real fun"
FarmBoyStroker is offline
post #3 of 13 (permalink) Old 06-27-2012, 04:57 AM
Mr.Wonderful's Avatar
Re: Ugly Wheels
I used the Mother's brand ball and compound on my rims. It takes a bit of time but they cleaned up pretty well.
1996 F-250 ex cab 4x4 100k miles. DIY intake from Riff Raff Diesel. 3"-4" diamond eye turbo back
Mr.Wonderful is offline
post #4 of 13 (permalink) Old 06-27-2012, 05:28 AM
strokeorcroak's Avatar
Re: Ugly Wheels
acid wash them....its the only way to go.
Then polish them up real nice after it
1996 with 35s
615hp/1258tq on 9/19
strokeorcroak is offline
post #5 of 13 (permalink) Old 06-27-2012, 09:05 PM Thread Starter
Re: Ugly Wheels
Thanks, took someone long enough to post id forgot i made this thread lol. I guess ill try the polish then the acid if poloshing doesnt cut it. What kind of acid though, like what you put in batteries, i have some of that in the barn i could use.
-Tyler-
post #6 of 13 (permalink) Old 06-27-2012, 11:04 PM
oconnors17
Re: Ugly Wheels
take them too a simi wash and tell them to acid bath them
oconnors17 is offline
post #7 of 13 (permalink) Old 07-03-2012, 12:46 PM
Re: Ugly Wheels
The best advice I can give is to go to NAPA and get a couple of cans of their gasket remover spray. Spray that on them and let them sit for a few minutes, you will see the clear coat start to release and you can just wipe / spray it off. Once the clear coat is gone you can polish them as you would any aluminum. I did this on an old Madura motorcycle I turned into a rat bike. The aluminum looked to be in REALLY bad shape but it was all in the clear coat.
Hope that helps!
slow96z is offline
post #8 of 13 (permalink) Old 07-03-2012, 03:47 PM Thread Starter
Re: Ugly Wheels
Well ill definitely try that cause the closest semi wash i found was bout an hour and a half away. Ill get some today, if it works ill post up a pic or two.
-Tyler-
post #9 of 13 (permalink) Old 07-06-2012, 05:59 PM
Re: Ugly Wheels
There is acid designed for cleaning aluminum.... I wouldnt use battery acid
1996 with 35s
post #10 of 13 (permalink) Old 07-01-2013, 11:45 PM
Powerstroke_T444E's Avatar
Re: Ugly Wheels
Try using "proform" its pretty heavy duty stuff, I use it to clean under the hood/oil/grease/whites of tires. Spray it on then let it set for 20 sec and scrub it, works wonders for me.
1996 Ford F-250 7.3L turbo diesel 192K 4X4 XL, EBPV delete
Powerstroke_T444E is offline
