Rusted hole in roof leaks inside.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-09-2012, 02:09 AM Thread Starter
Not sure if this should go here or fab.
Anyway my center clearance light is rusty as hell around the base... Since its on top I wasn't to worried. Until we had a good rain. Then every time I accelerated a few drops of water would drop from the lie-o-meters little plastic display.... I figure it has to be coming from this rusty patch.
How would y'all fix this? Ive never done any kind of body work before. I plan on learning to paint eventually so if I do any work on this I figure it might as well be my first project....
I would assume just wire wheel/sand away all the rusted crap metal then put fiberglass over it, but I don't think that will hold the clearance screws well.... Another thought is having to cut out the piece and weld a new piece of metal in there.... Like I said never done any fab work so I need thoughts. The body has a couple good rock dings and paint chips so I might as well Make a whole project out of it.... I will be learning to do everything from welding to fiberglass to paint...
My phone won't post pics with the auto guide app so if the description isnt good enough let me know and I'll post when I get home
Sent from my Autoguide iPhone app
01 F250 CCSB, BTS, ICON 4" on Bilsteins, 35" Toyo MT on 18" Fuel Hostage, DP F6 Tuner, 6637, 5" pipe, AIH delete, EBPV Delete, Recon Smoked lights all around, 35W Retro HIDS,
HEROS NEVER FALL.... THEY EARN THEIR WINGS.... RIP LCPL JASON D. HILL - IRONMAN, YOU WILL NEVER BE FORGOTTEN. SEP 18 1990 -JUNE 11 2011
pbguy420 is offline
post #2 of 6 (permalink) Old 02-10-2012, 12:59 PM
31 YNOT's Avatar
Re: Rusted hole in roof leaks inside....
IMO I would bring it to a body shop and see what they could do for you. It may cost a bit more but it would be done right then. Then if it leaks anymore its on them
Matt
2011 CC/LB King Ranch 6.7 White Tri Coat 4x4
Mods: Truck Nutz and dodge tow mirrors
31 YNOT is offline
post #3 of 6 (permalink) Old 02-10-2012, 01:33 PM
Intelligent Burro
Just had my 99 done. Removed cab lights, removed windshield, repaired rust around lights and windshield, repainted roof, installed new windshield. $800.
E99, F250, 7.3, CCLWB, Auto, manual 4x4, AIS intake, AD injectors, PHP FU, AIC, 3:73 gears. Autometer Gauges - (EGT, Trans Temp, Boost), Edge CTS
Dieselpop is offline
post #4 of 6 (permalink) Old 02-10-2012, 02:59 PM Thread Starter
ya 800 bucks id rather spend on the tools to do the job.... so i can do whatever body work i need again down the road....
anybody
pbguy420 is offline
post #5 of 6 (permalink) Old 02-10-2012, 03:54 PM
Traveler's Avatar
The easiest way to do it is like you are thinking with fiberglass. Pull the light, grind out the rust, treat it.
Now use layers, at least 3 of fiberglass matting and resin. It will hold the light just fine.
The best way is pull the headliner down, cut out all of the rusty metal and weld in a patch.
Then of course fill and paint it. But that is so labor intensive.
Traveler is offline
post #6 of 6 (permalink) Old 02-12-2012, 01:20 AM
STILL LEARNING
Bradbilt's Avatar
1st you need to find out if that is the spot that is the cause for the leak.
If it is.....
CUT out the RUST and weld or Bond in a new piece of METAL
Bradbilt is offline
