Aluminum Polish??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-03-2012, 02:44 AM Thread Starter
OBS all day long
sprtmetz10's Avatar
Aluminum Polish???
I'm looking for some good aluminum polish to polish my wheels and my bedrails. and another thing is whats a good product for removing brake dust off your aluminum wheels?...is there a sealent that works good for sealing out the elements and keeping your shine?
.96Stroker.
sprtmetz10 is offline
post #2 of 13 (permalink) Old 02-04-2012, 01:58 AM
captivahach's Avatar
Re: Aluminum Polish???
Depending on how bad they are,
First pick up a good cleaner, If really bad i'd just give them a acid bath if your planning on polishing anyways.
Second i like never-dull polishing pads, kinda aggresive
Third then i've always loved mothers polish to finish it up
When i polished motor cycle frames, swingarms, wheels etc I actually water sanded starting at usually 600 grit up to 2000
2000 F250, 6" bds,20'' kmc hoss with 37 procomp Xtreme AT's. S&B stage 2 intake,4" proflow bellowed up-pipes,php custom tunes, swamps S/175/146 injectors,04 headlights,warn hubs, Pricol gauges,built tranny low stall billet convertor, Kenwood excelon headunit, rockford fosgate t400.4 and t1500.1,image dynamic componets with 4 10's,
captivahach is offline
post #3 of 13 (permalink) Old 02-04-2012, 02:27 AM
black_pstroke's Avatar
wet sand with a very high paper somewhere in the 2000 range. then polish them, I prefer mothers my self they will look great.
2009 F-250 FX4 Icon, Toyo, Fuel, Bilstein, IDP/SCT, Flopro
black_pstroke is offline
post #4 of 13 (permalink) Old 02-04-2012, 03:50 AM
kramarj's Avatar
I used to like Mothers, but found White Diamond. There is no comparison, White Diamond is way better. It is a little expensive, but it is amazing. White Diamond Metal Polish and Sealant Check out their videos, it really speaks for itself. It is also supposed to be a sealant too, I don't drive my truck in the winter, so I can't really say how well it works, but it is supposed to seal it.
Joe
97' F-250HD. ECLB. 65,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
kramarj is offline
post #5 of 13 (permalink) Old 02-04-2012, 04:15 AM
SUPERDF350's Avatar
The product I use to polish airplanes is called Nuvite. It is a little pricey but hands down the best product to clean and polish aluminium
2003 F-350 CCLB 4x4 6 spd man 5.5 Fabtech, 4"turbo stright piped,DP Tuner, hi-idle,40,60,80,100,120, ATS housing wicked wheel, tymar intake,firestone airbags.
SUPERDF350 is offline
post #6 of 13 (permalink) Old 02-04-2012, 05:07 AM
powerstroker6.0
StrokerSmoker01's Avatar
Go to autozome get aluminum britghtner by purple power should be in a gallon jug stuff works wonders
05/6.0/ccsb/fx4/lariat/Egr delete/Sct/Airdog2 165 gph/Powermax/6.4 banjos/5 inch mbrp/120k/SOLD
96/f250/7.3/5spd/rclb/35s/ts by beans/330k/SOLD
01/3500/6spd/4x4/Fully built/Riding on 22.5s/313k
StrokerSmoker01 is offline
post #7 of 13 (permalink) Old 02-04-2012, 02:06 PM
Administrator
Zmann's Avatar
Flitz is my fav
http://www.flitz-polish.com/index.ph...FWnatgodC0rQ3Q
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 13 (permalink) Old 02-06-2012, 02:52 AM
mwalsh9152's Avatar
aluminum acid and a brush to clean it, then Wicked Products lightning shine in heavy coats to polish it up. After you get it shining, put a good coat of wax over it to seal it.
1995 7.3 Bronco
mwalsh9152 is offline
post #9 of 13 (permalink) Old 02-25-2012, 12:38 AM
mours2's Avatar
Check out caswellplating.com, that's where i get all my materials for polishing from... they even have a kit for polishing a turd...LMAO...
mours2 is offline
post #10 of 13 (permalink) Old 02-26-2012, 02:03 AM
31 YNOT's Avatar
The best polish that I have found so far is called Metal Wax. It has a cleaner then a the polish then a finisher. It is all a quick on off process. Check out there site they have videos on how to use it
Here are some hub caps off a 69 F-100 that my grandpa wanted polished. They all looked like the bad one, took me about 7min to clean the one on the right up I just did this on Friday
Matt
2011 CC/LB King Ranch 6.7 White Tri Coat 4x4
Mods: Truck Nutz and dodge tow mirrors
31 YNOT is offline
