tint and nightshade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 01-26-2012, 02:51 AM Thread Starter
3brorce's Avatar
tint and nightshade
Best way to remove double layer limo tint and glue?
Also, best way to remove nightshade from tail lights without hazing the plastic?
Thanks
03 6.0 Full EGR delete, S&B CAI, 4in turbo back, 70hp injectors, Moded Banjos, fuel spring mod, GearHeads, RCD, IDP and TSD tuned, trans temp, boost, egt, fuel press, MIA
08 6.4 4in dp. 5in TBE. S&B, Studs, EGR delete, No limit elbow/CAC pipe, Spartan, TSD, QTP and IDP LW tuned
07 5.9 5in TBE, Goerend, Fass, EFI Anarchy Diesel Tuning
3brorce is offline
post #2 of 25 (permalink) Old 01-26-2012, 03:03 PM
Zrock's Avatar
Re: tint and nightshade
they make a spray on tint remover for the window tint... Worked great when i did my truck. Left no glue or anything behind
Zrock is offline
post #3 of 25 (permalink) Old 01-26-2012, 03:40 PM
StackinChipsLikePringles
WoodBoy's Avatar
Send a message via Skype™ to WoodBoy
Straight ammonia. Spray it on the window tint, put a plastic bag over it to keep it from evaporating off and let it soak in for a while. Keep it soaking for a little while and it will come right off.. I am not sure about the nightshade
2010 F250.. Stock looking
What is right is not always popular, and what is popular is not always right.
WoodBoy is offline
post #4 of 25 (permalink) Old 01-26-2012, 03:58 PM
06-6.0 stoker's Avatar
As for the tail lights.. Try wet sanding with 120 then 240 then 400 the use a buffer and wax to bring the shine back.
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #5 of 25 (permalink) Old 01-27-2012, 03:47 AM
Typically buffing plastic is a no no. And your never going to get it shiny with just 400, I would definately go up to 1500. Plastic burns easy when buffing, it can be done you just have to go easy with it otherwise you will be snading the burn marks out and doing it again.
BlueOvalDiesel is offline
post #6 of 25 (permalink) Old 01-27-2012, 06:35 PM
Depends on if you use a serious buffer or a low speed polisher. The low speed would be best but I have done headlights and marker lights with a normal buffer before. Just have to pay attention and take your time
post #7 of 25 (permalink) Old 02-02-2012, 03:21 PM Thread Starter
3brorce's Avatar
Anyone tried goo gone to get nightshade off tails?
3brorce is offline
post #8 of 25 (permalink) Old 02-02-2012, 03:25 PM Thread Starter
3brorce's Avatar
Any idea what kind or where you got it?
3brorce is offline
post #9 of 25 (permalink) Old 02-03-2012, 01:36 AM
ChaseN's Avatar
no man don't take the tint off haha.
i got my new truck tinted the same way that one was, only a lot lower brow!
the tailights, you'd be better off buying new ones, instead of trying to take it off. or txt me, i have a set of brand new ones for 08 i might trade ya...
2013 F250 Platinum C/C 4x4 SWB
2013 F150 Platinum C/C 4x4 SWB
ChaseN is offline
post #10 of 25 (permalink) Old 02-03-2012, 01:40 AM
Nose picker
Peel the tint off and scrape the glue with a razor blade and use windex as a lubricant.
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
