Fender flare adhesive - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-24-2011, 04:32 AM Thread Starter
Took off my flares a few months ago. Any body have any leads on good chemical removers? Looks like the post below says something about an eraser wheel, but I'm looking for a chemical fix on the cheap. It's just a few spots where the 3m adhesive didn't come off, so nothing big, but still hard tonget off. Appreciate any help.
deucefifty is offline
post #2 of 10 (permalink) Old 06-26-2011, 04:54 PM
Zrock's Avatar
Re: Fender flare adhesive
A little paint thinner will soffen up the glue and a little bit of rubbing and it will come right off..
Zrock is offline
post #3 of 10 (permalink) Old 09-07-2011, 12:23 AM Thread Starter
Zrock- that wont strip my clearcoat or damage my existing finish will it?
post #4 of 10 (permalink) Old 09-07-2011, 01:37 PM
'05 Excursion
Term3's Avatar
I would use WD-40 as I'd be worried about what paint thinner would do to the finish. I've used WD-40 lots of times to remove road tar and adhesive from stickers.
Term3 is offline
post #5 of 10 (permalink) Old 11-17-2011, 06:54 PM
3M Adhesive Remover, you can buy it at NAPA or just about any other parts store.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #6 of 10 (permalink) Old 11-17-2011, 07:03 PM
Layson's Avatar
I am real hesitant to use any chemical compounds. I have had bad experiences with some chemicals that were paint friendly. The erasure actually is the quickest remedy I have seen yet. I have taken several 3M stainless rocker panels off and it works great. No paint damage, you would be surprised at how fast it works.
Layson is offline
post #7 of 10 (permalink) Old 11-17-2011, 07:13 PM
Factory paint will not be damaged by those chemicals, only lesser aftermarket paint compounds like lacquer or enamel would be. I have used 3M Adhesive Remover, Lacquer Thinner, and Mineral Spirits and none have done any harm to factory paint on my Super Duty.
post #8 of 10 (permalink) Old 11-17-2011, 11:24 PM
Administrator
Zmann's Avatar
I always start with WD-40 and work up
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 10 (permalink) Old 11-19-2011, 01:04 PM
Believe it or not Goof Off Gel works great with no problems to the clear coat or paint. just go easy with it as a little works well.
Outlaw350 is offline
post #10 of 10 (permalink) Old 11-22-2011, 05:22 AM
theoldgirl1990's Avatar
I agree with layson, I purchased the 3m eraser for my drill and it takes anything off windows or paint without damaging the surface. You can buy it at napa for around 30 dollars.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
