Got me a new truck! - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 12Likes
post #31 of 54 (permalink) Old 04-19-2019, 07:47 PM
alleged moderator
tjctransport's Avatar
Re: Got me a new truck!
i want to say pre 86 used the 1/4 inch oil pump drive rod, 87-newer uses the 5/16 drive rod.
@Dustybumpers what say you Charlie?
tom
tjctransport is offline
post #32 of 54 (permalink) Old 04-21-2019, 04:16 PM Thread Starter
Project Shamu
Lt.Dan's Avatar
Originally Posted by Blue-Truck-Nut97 View Post
Nice truck!
The firing order should be embossed on the intake, between the dist and carb, is your dist bad?
And if memory serves me, a distributor from any 289 or 302 will fit the hole, but I think they are by themselves in that respect.
I just counted the plugs on top of the dizzy, its the 1-5-X firing order, doesn't match the 351.
Originally Posted by longjonsilver View Post
Originally Posted by Lt.Dan View Post
a 408 would be nice, but who knows how hard it would be to swap and get CARB approved.
It has an AOD trans.
I’m not up on California emissions stuff but I don’t see how putting a “ cleaner” fuel system on the truck would be a no no . Course anything is possible . Wonder if it would be worth retrofitting a factory EFI setup into the truck .
An EFI kit would definitely run cleaner, but I have to change intake manifold, (which no one makes a CARB approved manifold), and the EFI kits are not CARB approved either, and that's all that matters.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #33 of 54 (permalink) Old 04-21-2019, 04:39 PM
Native Texan
masakimm's Avatar
Garage
Swap in an efi motor then its already approved.
Explosive Diarrhea not ur friend but a great weight loss tool.
longjonsilver likes this.
Upgrades:
masakimm is offline
post #34 of 54 (permalink) Old 04-21-2019, 05:36 PM
longjonsilver's Avatar
Id be in the move away from California approved modification lol .
So youre basically stuck with stock ?
tjctransport likes this.
longjonsilver is offline
post #35 of 54 (permalink) Old 04-21-2019, 08:58 PM
Blue-Truck-Nut97's Avatar
Just curious, what if you title/license it as an antique? Would that exempt you from the emissions stuff?
Blue-Truck-Nut97 is offline
post #36 of 54 (permalink) Old 04-21-2019, 09:21 PM
PSN intsigator
heavydoc's Avatar
You are finding all the threads we play in, you are fitting in nicely
Blue-Truck-Nut97 likes this.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #37 of 54 (permalink) Old 04-21-2019, 09:57 PM
don't play well w others
Dustybumpers's Avatar
83 last year for the flat tappet, also has old firing order. also least amount of horse power. is a tough motor, but hard on fuel. Heads are junk J U N K junk
small oil driveshaft, and it will twist off if you over rev it
Roller cam starts in 84. EFI in trucks 5.0 starts in 85 5.8 in 87 pickups, 89 vans
My suggestion , find a 95'97 1/2 sploder, yank the 5.0, stick it in there, put the smog on it to appear to work, and have some fun
The 95 sploder is a gt40 right out of the box. if you get one for a manual trans, you can run the AOD, which is the better trans, you just have to adjust the tv cable, and it will do what you need it to do without a stand alone controller.
I can help with making the stock motor better, but it's only a matter of time before it burns a valve, or cracks a valve seat. Did I mention the smog heads on there are JUNK?
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is online now
post #38 of 54 (permalink) Old 04-21-2019, 10:01 PM
That answer for Kalifornikate is no
Emissions testing starts in 1978 year, no matter the tag.
Normal states recognize the value of a historic viehicle
Charlie
post #39 of 54 (permalink) Old 04-21-2019, 11:28 PM
Ok, that's a bummer, I don't engage in californication so didn't know, but thought it might be a loophole.
Maybe it needs one of the new baby powerstrokes from a 1/2 ton grafted in??
post #40 of 54 (permalink) Old 04-21-2019, 11:36 PM
Not sure how kalisilly works. When md was still being stupid I put a 85 small block in a 80 mustang. They failed it big time.
It passed tail pipe sniff test
Didnt pass visual inspection because it didnt have an AIR pump.
Pretty sure only diesel he could put in would be a 6.9 idi.
I think that came out late 84, so probably no on that too
Charlie
Similar Threads
I got a new truck, Yall are gonna hate me. blackwaterstroker General Questions & Discussion 59 01-12-2010 09:10 PM
Got me some new tires mazdaparts General Questions & Discussion 6 02-28-2009 03:38 PM
Truck got the better of me today... jvencius 1999-2010 Super Duty General Aftermarket 10 02-12-2008 02:07 AM
