Good day. I have imported a 2003 4.6 & 5.4 V8 engines and Transmissions, complete with the original PCM, Transponder key and Transceiver module. There is 4 wires on the Transceiver modules and I have no clue of which wire is #1 to #4. I need a wiring diagram for each wire, as per the attached, which are +12v, Ground, TX and RX to enable the PATS function to be able to start the engine. Thanks in advance
