Fuel bowl heater - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-12-2019, 02:21 PM Thread Starter
Fuel bowl heater
Looking where the location of the fuel bowl heater fuse is on my 96 f250. Changed the fuel filt the other day and notices the heating element was not intact anymore. Now today went out to start it and all it does is crank. I have read that if that fuse blows your vehicle will not start.
Rooster16 is offline
post #2 of 9 (permalink) Old 10-12-2019, 02:48 PM
Re: Fuel bowl heater
Rooster,
Check fuse 22 in the fuse fox that is under the hood. Had this happen to me the first year I had my 97 cclb. Make sure to disconnect the fuel bowl heater first..
Cj
1997 F350 CCLB 7.3, Eaton Fuller RTO-6610, 4x4, 3.54, otherwise stock
cjfisher is offline
post #3 of 9 (permalink) Old 10-12-2019, 03:48 PM Thread Starter
Ok thanks. I'll double check but I think they were all good. Any other suggestions? All I'm getting is cranking right now. The heating elements doesn't have to be installed after the fuse is replaced does it? Plan on running it without until I get a new one
post #4 of 9 (permalink) Old 10-12-2019, 06:48 PM
College Student
Just unplug it from the filter housing and leave it be. No need to get a new element. With the quality of fuel at the pumps and that it is usually pre mixed, you won't really have to worry about it gelling up. Just replace the fuse and start driving. Mine broke and I pulled it two years ago and haven't had a problem.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #5 of 9 (permalink) Old 10-12-2019, 07:28 PM
Rooster,
Wouldn't hurt to check fuses 8 and 9 in that same fuse box. You can also check the PCM relay and IDM relays.
Cj
cjfisher is offline
post #6 of 9 (permalink) Old 10-12-2019, 07:47 PM
You can also go back to fuse 17.. This is the fuse that protects the key switch.
Cj
cjfisher is offline
post #7 of 9 (permalink) Old 10-12-2019, 09:09 PM
alleged moderator
tjctransport's Avatar
as said, eliminate the fuel heater and tape off the wire. then abandon it.
the heater is not needed unless you are in arctic regions. .
tom
tjctransport is offline
post #8 of 9 (permalink) Old 10-13-2019, 01:42 AM Thread Starter
Fuse 22 was what it was thanks guys for all the info.
post #9 of 9 (permalink) Old 10-13-2019, 01:51 AM
Bugman's Avatar
If you don't disconnect the heater wire from the outside of the filter housing you may have the problem again
Sent from my SM-J737V using Tapatalk
Bugman is offline
