Hi need some help 2000 Ford f250 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-17-2018, 03:16 AM Thread Starter
Got a Ford F-250 7.3 turbo I replaced the fuel pump and still have a whining noise coming from the fuel pump and when that starts the the truck starts losing power and then dies I need help anybody with the same situation any information will be thankful
ramrod7272 is offline
post #2 of 4 (permalink) Old 12-17-2018, 06:18 PM
Dieseldoctor
Fordeverlasting94's Avatar
Send a message via Yahoo to Fordeverlasting94
The first thing you need to check is fuel pressure. It sounds like you may have a clogged pickup line in your fuel tank. If you dont have access to a FP test gauge than I would recommend blowing pressurized air back thrue the feed line going from the tank to clear any debri. This will only by temporary and if that is the problem than I would recommend doing the fuel tank mod that a lot of guys do.
1994 f250 4x4 exc lb 7.3 powerstroke zf5 speed 378k 3.55 gearing 10.25 sterling LS rear axle, dana 50 ttb front axle, 235/85r16 cooper's
Napa 6637 air filter, 120v idm, everything else is stock.
Fordeverlasting94 is offline
post #3 of 4 (permalink) Old 12-17-2018, 07:00 PM
PSN intsigator
heavydoc's Avatar
Re: Hi need some help 2000 Ford f250 7.3
Welcome to the nation
Sent from my super awesome outdated Samsung phone while waiting for masakimms# 500mA overdraw draw to catch fire which turd will be blamed for and we will be sitting on dustybumpers tailgate watching the fire and plotting against yommy.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #4 of 4 (permalink) Old 12-17-2018, 07:01 PM
PSN intsigator
heavydoc's Avatar
Yep test fuel pressure
heavydoc is offline
