I need answers please - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Bugman
post #1 of 8 (permalink) Old 11-17-2018, 02:24 AM Thread Starter
Tylerjxd's Avatar
I have a 2002 7.3 and it was smoking for a couple days then one day it was smoking really bad and had a loss in power. I brought it to autozone and it was clear of codes. As I was heading back home it started to knock and pulled it in driveway still smoking bad and shut it off. Replaced fuel filters and checked oil. Then went to start it again and it made a horrendous grinding noise. Now I go to start it and it just clicks and won’t do anything. Any ideas? I was going to get starter off and test it but don’t know where to go from there.
Tylerjxd is offline
post #2 of 8 (permalink) Old 11-17-2018, 02:58 AM
Tyler N Savannah Storey's Avatar
I would turn the engin by hand make sure its not locked up the knocking could be the injectors but id rule out it being a spun rod bearing first and go from there
Tyler N Savannah Storey is offline
post #3 of 8 (permalink) Old 11-18-2018, 08:03 PM
S&R Powerstroke
Re: I need answers please
Greetings. Sorry about your truck issues. I'm sure after you get through it all you will have a good running truck. Well first thing first make sure you got enough juice from the batteries to turn over the 7.3 over. Before condemning starter, check your batteries and charging system first. Possible fuel issues causing knocking, smoking and
lack of power. Possible fuel pump issues sucking in air. Possible injector or injector oring failure. Remove the fuel filter and inspect air in the fuel system while fuel pump
activated.
Sonny Caraffa is offline
post #4 of 8 (permalink) Old 11-18-2018, 08:08 PM
alleged moderator
tjctransport's Avatar
what were the codes they cleared out of it?
tom
tjctransport is offline
post #5 of 8 (permalink) Old 01-20-2019, 05:32 PM Thread Starter
Tylerjxd's Avatar
it was 3 degrees out this morning replaced injectors a month ago went out and tried to start my 7.3 and its locked up where do i go from here
Tylerjxd is offline
post #6 of 8 (permalink) Old 01-20-2019, 07:45 PM
KIB7.3's Avatar
Garage
Pull the glow plugs and turn over the motor to get the fuel out of the cylinders. I would say you had an o-ring go out or an injector fail. Where did you get your injectors?
XLT CCSB, 4x4, 3" Downpipe, 4" Exhaust (with CAT delete), 140V IDM Mod, TS6 Position Chip, K&N, Transmission built by State to state transmission in AZ
KIB7.3 is offline
post #7 of 8 (permalink) Old 01-20-2019, 08:24 PM Thread Starter
Tylerjxd's Avatar
i had them rebuilt by a guy in california and he bench tested them and put new o-rings you think they went bad already
Tylerjxd is offline
post #8 of 8 (permalink) Old 01-20-2019, 09:24 PM
Bugman's Avatar
It could be fuel or coolant, until you pull the glow plugs out and find out what is in the cylinders you won't know which way to go.
A O ring could of been cut when the injector was installed or there might be a bad injector cup. Lots of unknown.
HilhavenFarm likes this.
Bugman is offline
