FASS 165gph Titanium Signature Series Fuel Air Separation System - 08-10 Ford F250/F350 Powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 05-15-2019, 07:27 PM Thread Starter
Sponsors
The Titanium Signature Series diesel fuel lift pump was engineered by FASS Fuel Systems to be the top performing, longest lasting and most reliable aftermarket filtration system in the diesel industry. Rated at 165 gallons per hour and backed by our limited lifetime warranty the Titanium Signature Series lift pump is capable of supporting your Ford Powerstroke 6.4L diesel engine with enough fuel for multiple fueling system upgrades. A Titanium Signature Series lift pump also offers advanced filtration benefits that will help protect your Powerstroke’s injection systems, effectively extending the life of both your Injection Pump and Injectors. These Benefits include an improved filtration rating of 2 Microns, built-in water separation filter, and FASS Fuel Systems patented air/vapor removal process. Powerstroke diesel engines are known for having injector failure issues; this can be caused by several different factors and FASS Filtration Systems is designed to eliminate those that are fuel related.
*New Bolt On Bracket Installation
*Preset 10 PSI Fuel Pressure
*Complete Replacement Pump
*165 Gallons Per Hour Flow Rating
*Removes Water, Air and Debris From Diesel Fuel
*2 Micron Filtration Rating
*Protects and Extends The Life Of Your Injectors
*Improved Cold Weather Starts
*Decreases Carbon Monoxide and Carbon Dioxide Emissions
*½ Inch Fuel Lines and Ports
*Fuel Mileage Improvement
*Improved Fuel Volume Delivery
*Smoother Engine Idle
PM with your ZIPCODE for an ACCURATE QUOTE!
Facebook:https://www.facebook.com/AristocratAutosport
Instagram:https://www.instagram.com/aristocrat_autosport/
Website:www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email/Paypal:[email protected]
Aristocrat Autosport is offline
Similar Threads
FASS 11-16 Ford F250/F350 Powerstroke 125gph/55psi Titanium Signature Series Fuel Air Separator Aristocrat Autosport Aristocrat Autosport 0 09-20-2018 08:11 PM
trans separation from block? crossy 6.0L Power Stroke Technical Info 3 02-10-2013 03:07 PM
best Fass titanium setup for mpg on the 7.3?? and other ?? carpenterhut93 7.3L Power Stroke - Aftermarket & Performance 13 05-27-2012 12:42 PM
Six Degrees Of Separation Powerstroke Racer Politics and Religion 0 02-04-2012 04:39 PM
