ReadyLIFT 2.5" Leveling Kit with Track Bar Relocation Bracket! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 03-22-2019, 12:27 AM Thread Starter
Sponsors
Aristocrat Autosport is now offering ReadyLIFT 2.5" Leveling Kits with Track Bar Relocation Bracket for 4WD 2011-19 F250 and F350 trucks at discounted pricing!
This will allow you to install up to a 35" wheel/tire combo AND keep the OEM ride quality and driveability of your truck!
The ReadyLIFT Leveling Kit includes 2.5" powdercoated steel coil spring spacers, OEM style cast iron track bar relocation bracket, sound isolators, shock extensions and sway bar frame mount spacers designed specifically for the 2011-2019 Super Duty platform. When it comes to leveling you get what you pay for. This great system specifically incorporates more than just front leveling. The addition of our track bar relocation bracket allows you to correct your truck's track width after lifting the front. Something that is necessary on some Super Duty trucks. The sound isolator is installed between the spacer and spring to retain that great OEM ride and quiet sound. Shock extensions allow you to retain the use of those great riding brand new front shocks rather than having to replace them with cheap aftermarket versions. In addition, Ford changed the front suspension on the new 2011-2019 Super Duty trucks and in order raise the front of the truck the front sway bar frame mounts must be spaced downward. ReadyLIFT designed new sway bar mount spacers just for this reason, something you won't get with other kits. If you are looking to make your 2011-2019 F250/F350 4WD sit perfect over 35" tires then this strong 2.5" Leveling kit is exactly what you need!
ReadyLIFT Smart Suspension Technology is used to make this kit very user-friendly to install, requiring no cutting or drilling. Like all other ReadyLIFT kits, this Leveling Kit is guaranteed for life against manufacturing defects.
PM us today for a special deal you won't find anywhere else! Just be sure to send us your ZIP code for an accurate out the door price!
Facebook:https://www.facebook.com/AristocratAutosport
Instagram:https://www.instagram.com/aristocrat_autosport/
Website:www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email/Paypal:[email protected]
Aristocrat Autosport is offline
Similar Threads
ReadyLift Suspension 08-16 Ford F250/350/450 Track Bar Panhard Relocation Bracket Aristocrat Autosport Aristocrat Autosport 0 09-27-2018 07:49 PM
readylift 1.5" leveling kit installed 08twinturbo 6.4L Power Stroke - Aftermarket & Performance 24 01-25-2012 10:11 PM
readylift trac bar drop bracket 06 stroker Suspension and Drivetrain 14 11-15-2011 09:34 PM
