Oil recommendations - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Larrgh
  • 1 Post By 02powerstrokin
post #1 of 8 (permalink) Old 03-21-2019, 09:16 PM Thread Starter
Oil recommendations
Have a 2011 F250 6.7 with 106,000 miles, needing to do my first oil change. I would consider my truck to fall under severe duty application due to mostly short distance trips to and from work. I will be pulling 11,000 pounds 2 to 3 times a month out of town, and I do live in Florida . My question is what brand of oil, weight, And should I run conventional, synthetic blend, or Full synthetic per my engine an application? And is there a better oil filter than Motorcraft? Thanks
69SS is offline
post #2 of 8 (permalink) Old 03-21-2019, 10:07 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: Oil recommendations
No full flow oil filter will be better than MC.
Motorcraft 10w30 is a synthetic blend. There's several options for 5w40 full synthetic.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #3 of 8 (permalink) Old 03-22-2019, 12:03 PM
Master BS'er
jamiesaun's Avatar
Keep it simple, Just put in what the manufacturer recommends.
Synthetic or non....your choice. I wouldn't because damn dude, that stuff is expensive and diesels take a bunch of oil. Up to you.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #4 of 8 (permalink) Old 03-23-2019, 09:04 AM
PursuitInterceptor
Your 6.7L will use 10w30 (synthetic blend) as the recommended oil. 5w40 (full synthetic) is listed for choice under "extreme" use. For specific details the owner's manual covers the differences in vehicle use.
You dig.
post #5 of 8 (permalink) Old 03-26-2019, 09:29 AM
Heavy....Motorcraft does not make a synthetic blended oil for the diesel. The choice is either dino or synthetic.
https://www.fcsdchemicalsandlubrican...Motor%20Oil%5D
HeavyAssault likes this.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Larrgh is offline
post #6 of 8 (permalink) Old 03-26-2019, 01:29 PM
Master BS'er
jamiesaun's Avatar
Synthetic blend basically has no meaning since there is no standard for what constitutes a "blend." It could be 5% 20%...could be anything.
I view synthetic blend and conventional as basically the same thing. There's also no standard for what additives constitutes "diesel oil." Pretty sure thats just a gimmick too.
Brother James
post #7 of 8 (permalink) Old 03-28-2019, 09:19 AM
PursuitInterceptor
I know Ford doesn't label it that way, but I'd say the "industry standard" for 10w30 IS to be a blend.
You dig.
post #8 of 8 (permalink) Old 05-17-2019, 02:13 AM
02powerstrokin's Avatar
I’ve ran everything from motorcraft, Quaker state ultimate durability full synthetic, rotella T6, Schaffer’s and have always had the infamous 6.7 oil change tick. Tried mobile1 full synthetic and no tick. I’m sure not all trucks would respond the same. I’ve always changed mine every 5k miles. Best of luck
02powerstrokin is offline
Similar Threads
7.3 oil cooler recommendations lckelly 7.3L Power Stroke - Aftermarket & Performance 6 02-02-2017 09:04 PM
Oil recommendations rfrostick Fluids Discussion 4 03-10-2012 03:45 PM
My first oil change on my 6.4... any recommendations/tips? Strokin6.4 6.4L Power Stroke - Technical Info 23 11-23-2011 08:05 PM
Any Recommendations On Stacks? Strokin' It 7.3L Power Stroke - Aftermarket & Performance 13 09-12-2007 02:32 AM
Up-pipe recommendations Pocket 7.3L Power Stroke - Aftermarket & Performance 28 09-11-2007 03:19 PM
