Rear seat back - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Dustybumpers
  • 1 Post By mastrkee
post #1 of 5 (permalink) Old 12-14-2018, 09:08 PM Thread Starter
Jackleg Mechanic
mastrkee's Avatar
Rear seat back
Hey PSN, I have a '17 CC and can't get the left rear seat back to lean forward. It's a 60/40 type seat. I was told by the salesman that the seat doesn't come down. I can hardly believe this to be true.
Do any of you have any input or experience with this?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #2 of 5 (permalink) Old 12-15-2018, 10:04 AM
don't play well w others
Dustybumpers's Avatar
Re: Rear seat back
mastrkee likes this.
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool like me."
Dustybumpers is offline
post #3 of 5 (permalink) Old 12-18-2018, 04:56 PM Thread Starter
Jackleg Mechanic
mastrkee's Avatar
Re: Rear seat back
Awesome find! Thank you for posting the video. Iíll be looking for that as soon as I get home.
Thanks again dustybumpers.
Dustybumpers likes this.
Jeff
mastrkee is offline
post #4 of 5 (permalink) Old 12-26-2018, 12:16 AM
Re: Rear seat back
My 2018 doesnít have the strap like the video shows, my 2012 and 2014 F150ís didnít either. What I did was (I figured this out on them) get the saeat forward, remove the latch assembly (two torx screws) and carefully drill a hole in the little pin you actually pull to get it to release. I canít remember the size I used as I made up a couple, and still had one. Anyway, I then got a very small key ring loop 1/2Ē or smaller. I then got some para cord that matched the rear seats. I cut it long enough that I could wrap it around the head rest and let the loose end drap back behind the seat. If you want I can take pictures tomorrow, and show you, but it is super easy, the hole you drill only needs to be large enough to get the loop through it. The perfect size loop is the size the Maglight Solitare uses.
mstennes is offline
post #5 of 5 (permalink) Old 12-26-2018, 11:25 AM
Re: Rear seat back
pictures would be great.
Charlie
