7.3 cold air intake - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 03-28-2017, 02:42 PM Thread Starter
lukewells7197's Avatar
7.3 cold air intake
I have a 2001 f350 7.3 and I'm looking into the s&b cold air intake.
I am currently running a ts6 position chip and am going to be upgrading to bigger injectors. Is s&b the way to go? Or should I go with something else?
lukewells7197 is offline
post #2 of 20 (permalink) Old 03-28-2017, 03:31 PM
Rookie diesel tech
evans735's Avatar
Send a message via AIM to evans735
Re: 7.3 cold air intake
i personally like the 6637 air in take mod
2000 F350 7.3L ext. cab, long bed dually, ZF6, 340,xxx miles
6637 mod/ egt and boost gauges/ PHP hydra
evans735 is offline
post #3 of 20 (permalink) Old 03-28-2017, 03:40 PM
MotherHucker
President's Avatar
I too have the 6637 mod on my truck and prefer it, was about 99 bucks from Riff Raff Diesel.
President is offline
post #4 of 20 (permalink) Old 03-28-2017, 03:47 PM
Rookie diesel tech
evans735's Avatar
^thats the exact one im using right now! works well brings alot more air into the engine, and comes with a sleeve to keep out the moisture and water. I feel it was money well spent, compared to the more expensive air intakes.
evans735 is offline
post #5 of 20 (permalink) Old 03-28-2017, 04:27 PM Thread Starter
Even with larger injectors and a ts6?
post #6 of 20 (permalink) Old 03-28-2017, 04:32 PM Thread Starter
And what filter? The regular, Donaldson blue, or big boost?
post #7 of 20 (permalink) Old 03-28-2017, 04:50 PM
79jasper's Avatar
I'm going to go against the grain here.
I would do the s&b. What I can't answer is if it will support bigger injectors.
Next would be the blue riffraff 6637. But same thing here.
And yes, I am running a standard 6637. Even with a newer filter, I can suck down the filter minder about 1/4.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #8 of 20 (permalink) Old 03-28-2017, 04:56 PM Thread Starter
I've heard good about both 6637 and s&b obvious difference is the price. What I would like to know if anyone had ran the big boost filter or not
post #9 of 20 (permalink) Old 03-28-2017, 05:07 PM
79jasper's Avatar
Where are you seeing the big boost filter?
79jasper is offline
post #10 of 20 (permalink) Old 03-28-2017, 05:24 PM Thread Starter
Riff raft diesel, when viewing the 6637 filters it shows the original filter, the blue, and a "big boost" filter
