No idle only if you throttle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 11-26-2015, 03:55 PM Thread Starter
Check your low pressure oil pump and the cam sensor my cam and crank where syn. But cam was still bad and the low oil pressure housing was cracked loosing oil pressure on start up. Also make sure that you buy your oil filter from ford it was cheaper then O'Reilly oil filter a d the filter is to spec. Per ford the cam and the low oil pressure has a lot to do with the idle. My trk is starting
Better then ever.
63panelvan is offline
