South Houston Engine Service - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 15 (permalink) Old 04-09-2015, 04:30 PM
All done now
Arisley's Avatar
Re: South Houston Engine Service
One out of 500 aint' bad odds.
Arisley is offline
post #12 of 15 (permalink) Old 05-07-2015, 12:00 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Oh my SHE motor...
Joe
CSIPSD is offline
post #13 of 15 (permalink) Old 08-08-2016, 07:52 PM
It's August 2016 now and I put a 7.3 South Houston Engine in an F-550 back in February; I had never heard of the company until then. We have hay farms and have pulled big hay loads around 25,000 pounds over mountain passes here in Colorado. Only about 6,000 miles on the engine right now, but we have had great luck so far. No leaks, good power, no weird sounds doesn't use any oil. All in all very happy. If you have questions, you can sure contact me as time goes on and I will give you an unbiased opinion. Good luck.
KCColorado is offline
post #14 of 15 (permalink) Old 04-18-2019, 01:05 AM
Robdog's Avatar
Kc, how’s your engine running? I’m getting ready to put a new one in my 550, I was looking at Ford remanufactured but wasn’t sure about the metal spray in the cylinders. Any recommendations?
Thanks, Rob
Robdog is offline
post #15 of 15 (permalink) Old 04-18-2019, 01:52 AM
Native Texan
masakimm's Avatar
Garage
Thanks, Rob
I hate to be the bad news bearer But he has one post ever in 2016 I would not hold my breath for a response.
Upgrades:
masakimm is offline
HTML code is On
