Which reloader should I buy - Page 43 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 32Likes
post #421 of 448 (permalink) Old 06-12-2019, 01:25 PM
Luddite in Charge
Mr_Andy's Avatar
Re: Which reloader should I buy
Originally Posted by Bugman View Post
Ya it all depends on what powder that I am using on what powder dispenser that I used to use. Then when I picked up the chargmaster all that changed. It dispenses any and all powders without a hitch.
I do all my loading on a old Lyman press that is real close to being worn out. So now I am looking for a Rockchucker at a good price. Hopefully I'll find one before my old one gives up. I thought about picking up a Dillon 550 a few years ago but figured that I would stick with what I have. I sat down and figured out that I had loaded over 40k rounds of pistol and rifle rounds on that press.
Sent from my SM-J737V using Tapatalk
I have a used one under the bench that the newer RC-II is bolted to. It's old as dirt but still tight. If you wanna do some horse trading for something lemme know.
Mr_Andy is offline
post #422 of 448 (permalink) Old 06-13-2019, 11:18 PM Thread Starter
PSN intsigator
heavydoc's Avatar
Well it's been a hell of a week so far. Haven't made it to a store yet, hopefully I can this weekend
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is online now
post #423 of 448 (permalink) Old 06-13-2019, 11:53 PM
Luddite in Charge
Mr_Andy's Avatar
It's something that becomes just part of what you do. Your feet are already wet. It'll come in time....
Mr_Andy is offline
post #424 of 448 (permalink) Old 06-15-2019, 07:44 PM
Luddite in Charge
Mr_Andy's Avatar
Well, get it unstuck and up and running yet?
Mr_Andy is offline
post #425 of 448 (permalink) Old 06-15-2019, 08:29 PM Thread Starter
PSN intsigator
heavydoc's Avatar
It's out, but never made it to the store. Spent all day doing yard work
post #426 of 448 (permalink) Old 06-15-2019, 09:49 PM
Luddite in Charge
Mr_Andy's Avatar
For giggles and chits after you get set up and familiar with whatever recipe you confirm with several book and reference black and white agreeing load don't forget about those 147's, just to see how they group. You never know. Do NOT take my memory as gospel but I believe I remember 19.0gr with a 140 with 4198 was a hot charge for the 140 so start at maybe 18.0 for the 7 grain heavier A-Max and work up. There's absolutely no correlation between 7 grain increase in projectile to reducing the load by a grain, that's just where I'd start and not worry about fingers and eyes. It *is* however a fact that as bullet weight goes up powder charge has to come down. There's no ratio formula or anything tho. Same with comparing CUPs to PSI with pressure, there is no rule to follow because they're comparing apples to oranges
If you ever need data just ask, and I'll definitely verify that 4198/140gr data before you do it. I have 6 go-to references I use between book and computer and never go with just one. Get 6 different charge ranges +/- a little bit among them all and I throw a dart in the middle and that's my start load.
Mr_Andy is offline
post #427 of 448 (permalink) Old 06-15-2019, 10:09 PM Thread Starter
PSN intsigator
heavydoc's Avatar
Thanks, and I will.
I already went with a heavier bullet and less charge and the fukin thing got stuck
post #428 of 448 (permalink) Old 06-15-2019, 10:15 PM
Bugman's Avatar
You just have to remember that 99% of anything that has to do with reloading is measured in grains and not grams
Bugman is offline
post #429 of 448 (permalink) Old 06-15-2019, 10:19 PM
Luddite in Charge
Mr_Andy's Avatar
Thanks, and I will.
Useless number - there's 7,000 grains in a pound. Handy when you're buying a pound of powder and don't know how many bullets and primers you'll need. So at 25gr of your 4198 charge you'd get 280 charges
Mr_Andy is offline
post #430 of 448 (permalink) Old 06-15-2019, 10:34 PM Thread Starter
PSN intsigator
heavydoc's Avatar
That's actually pretty good info
HTML code is On
