6.4 to 7.3 cab swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Bugman
post #1 of 4 (permalink) Old 02-25-2019, 04:47 PM Thread Starter
6.4 to 7.3 cab swap
I have a 99 f350 with the 7.3 with large amount of rust, dents, and scratches on the cab, but the motor runs and works great. when looking around online I found a 2010 6.4 with a blown motor for a very low price, and i was wondering if i could swap the cab from the 2010 onto the frame of my 99, and if it was possible to power the new technology that comes with the 2010 cab, I will really appreciate the advice and ideas you all have.
99F350Project is offline
post #2 of 4 (permalink) Old 02-26-2019, 01:21 AM
Bugman's Avatar
Re: 6.4 to 7.3 cab swap
I think that you would be money ahead by putting a used engine into the 2010.
Sbluke55 likes this.
Bugman is offline
post #3 of 4 (permalink) Old 02-26-2019, 05:00 PM
Moderator
Sbluke55's Avatar
The fire wall if different from 08-16. Itís the same from 99-07 though.
01 f-250, Standard
Sbluke55 is offline
post #4 of 4 (permalink) Old 02-27-2019, 02:37 PM
Ford Man
Wood's Powerstroke's Avatar
Garage
Send a message via Skype™ to Wood's Powerstroke
Hello and welcome to the Nation. To answer your question directly - anything is possible with enough time, money, and skills. Question would be how much of the aforementioned do you have? If you want a project then that would be a good one. IMHO, a 7.3 engine into a 6.4 truck would be a cool swap. The amount of work would be tremendous to get everything up and working properly but it would definitely be cool. @Bugman has a good point, though. A used 6.4 engine may be a better fiscal decision and would definitely be a whole lot less work. Literally plug & play.
Wood's 7.3
Old School Strokin'
2001 F-250 7.3 Powerstroke
Lariat, 4X4 Off-Road, Crew-Cab, SB, AT
Wood's Powerstroke is offline
Similar Threads
Cab swap 1993 crew cab on 1997 cal frame crank with no start. Davidr34 7.3L Power Stroke Technical Info 3 12-19-2017 05:01 PM
Tranny swap 4r100 swap for 5r110 Psdnec 7.3L Power Stroke Technical Info 12 09-25-2011 10:31 PM
Truck weight reg cab extended cab crew cab 4x4 2000psdbio 7.3L Power Stroke - Aftermarket & Performance 28 04-24-2010 04:59 AM
to swap or not to swap strokin09 1994-1997 OBS Power Stroke - Aftermarket & Performance 22 04-14-2010 04:19 AM
