2017 6.7 IN A 2011 F-350 2WD LB SC - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-16-2018, 04:13 PM Thread Starter
Has anyone done one yet? I just finished and have a couple issues I need help with. p0243 wastegate sol A and p2185 ECT sensor 2 ckt high. The rest I think will be cured with a tune. Thanks in advance, Walt
michigander is offline
post #2 of 10 (permalink) Old 10-16-2018, 10:41 PM
sooty
Re: 2017 6.7 IN A 2011 F-350 2WD LB SC
Did you replace the unit entirely, turbo to pan?
sooty is offline
post #3 of 10 (permalink) Old 10-17-2018, 02:24 PM Thread Starter
Yes, I used the fuel rails (Has the 2017 injectors in it) and harnesses off the 2011 and still has the 2011 ecm.
post #4 of 10 (permalink) Old 10-17-2018, 02:39 PM
sooty
The 17 engine has different turbo parameters and no wastegate solenoid, hence the codes. You need tunes for a 2015+ turbo and you should be all set.
sooty is offline
post #5 of 10 (permalink) Old 10-17-2018, 02:50 PM Thread Starter
Great! I have an EZ LYNK autoagent 2.0 unit that I tuned my 2015 F250 6.7 with hopefully 2015 and up tune will work on my 2011 ecm.
post #6 of 10 (permalink) Old 10-17-2018, 03:26 PM Thread Starter
Hopefully they will be able to provide that seeing it is a 2011 pcm.
post #7 of 10 (permalink) Old 10-17-2018, 10:53 PM
sooty
Most good tuners just modify the 11 flash. My 11 runs a stroker fuel pump and modded 17 turbo and runs just fine. Use a reputable tuner.
sooty is offline
post #8 of 10 (permalink) Old 10-18-2018, 02:23 PM Thread Starter
Thanks for the input. I need to get this truck running. Who would you recommend? I am waiting a response from GPD for my EZ LYNK. I have a referral to PPEI / Kory Willis but have not called them yet.
post #9 of 10 (permalink) Old 10-18-2018, 02:26 PM
sooty
Call tyrant or TSD
sooty is offline
post #10 of 10 (permalink) Old 12-07-2018, 03:43 PM Thread Starter
Call tyrant or TSD
Thank You, Thank You, Thank You! Tyrant hooked me up. Love my EZ LYNK!!!
