1995 powerstroke moves forward in neutral? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 15 (permalink) Old 08-31-2018, 01:35 PM Thread Starter
JoJo's Avatar
Been hanging around reading and learning for a while... washing what I got. Im running into a problem with the drivetrain and not sure what to do as I can't find info on the subject...
I have 280,000 on original transmission... e4od, and its been running and shifting perfect. I tried to back into a parking space the other day and it seemed like the truck was under a load.... it didnt want to go but did. I checked fluids and all normal. I put the gear selector in neutral and it moves forward a little... and a little more when I increase rpms. I got under the truck yesterday and could hear some rattling from the torque converter, pulled the shield off of it to visually inspect. Nothing appeared to be obviously broken, leaking or loose. I could rotate it by hand but with difficulty. It still shifts perfectly while driving but it has a hard time in reverse and is under load in neutral.
Any ideas?
JoJo is offline
post #2 of 15 (permalink) Old 08-31-2018, 02:56 PM
Master BS'er
jamiesaun's Avatar
Re: 1995 powerstroke moves forward in neutral?
Look at the shift cable adjustment
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 15 (permalink) Old 08-31-2018, 03:38 PM Thread Starter
JoJo's Avatar
Looks normal. Seems to be adjusted appropriately.
JoJo is offline
post #4 of 15 (permalink) Old 08-31-2018, 03:55 PM
Master BS'er
jamiesaun's Avatar
How did you determine that?
Re adjust it. Ya can't tell by looking at it.
Brother James
post #5 of 15 (permalink) Old 08-31-2018, 05:29 PM Thread Starter
JoJo's Avatar
Well I went out there and got underneath the truck while someone was moving the gear selector to different gears. I watched as the selector moved from one gear to the next, clicking solidly and remaining in place. There doesn't appear to be any damage to the area and everything looks like it normally does. I took the linkage off and moved the arm on the transmission through its full range of motion. It moved solidly and didn't feel loose or damaged. I looked at the linkage/cable from the steering column... doesn't appear to be adjustable. What do you mean adjust it?
JoJo is offline
post #6 of 15 (permalink) Old 08-31-2018, 06:28 PM
Master BS'er
jamiesaun's Avatar
K. Try shutting it off in neutral next time it's lurching forward, then get underneeth and pop the linkage off. Then see if the lever clicks into a spot.
Brother James
post #7 of 15 (permalink) Old 09-01-2018, 12:13 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
That's not going to cause it to load up in neutral. No matter how far the linkage adjustment is off, it can't engage forward and reverse at the same time. That's what is causing it to load up in reverse, and move forward in neutral. My educated guess is that the forward clutch is damaged and won't fully release.
BBslider001 and Lt.Dan like this.
Mark
Mark Kovalsky is offline
post #8 of 15 (permalink) Old 09-01-2018, 01:32 PM
Master BS'er
jamiesaun's Avatar
Good deal, cuz if it's wasn't the adjustment then I was out of ideas.
Brother James
post #9 of 15 (permalink) Old 09-02-2018, 10:23 PM Thread Starter
JoJo's Avatar
Yep... the linkage is working perfectly. Do you think that it is in the transmission or the torque converter? When I drained the torque converter and turned the truck on, moved it through the gears it seemed to idle in neutral like it normally would for a few minutes. Then it started again. When the truck is off it will roll backwards in neutral just fine.
JoJo is offline
post #10 of 15 (permalink) Old 09-02-2018, 10:24 PM Thread Starter
JoJo's Avatar
Thanks for the idea
JoJo is offline
