4r100 in 97 f350 not shifting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 05-24-2018, 01:44 AM Thread Starter
redkw's Avatar
I put a 4r100 in my 97 and while in drive it will not shift out of first. I can manually put it in second but otherwise nothing happens. reverse works also. Any ideas?
1997 F350 XLT CCLB Dually 7.3 Powerstroke Automatic 2wd 3 inch straight thru muffler to 4 to 5 to 7 inch miter cut stacks
1997 F350 XLT CCLB SRW 7.3 Powerstroke Automatic 4x4 3 1/2 inch straight pipe
redkw is offline
post #2 of 30 (permalink) Old 05-24-2018, 12:49 PM
410customs's Avatar
Re: 4r100 in 97 f350 not shifting
what was in the truck before the 4r100?
Where did this 4r100 come from?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 30 (permalink) Old 05-24-2018, 01:53 PM Thread Starter
redkw's Avatar
Came from a 98 e350 van
redkw is offline
post #4 of 30 (permalink) Old 05-24-2018, 01:58 PM
410customs's Avatar
okay so you installed a used trans from a 98 E350 into your 97 that was already an automatic correct? (just asking if you did a 5 speed to auto conversion)
Are there any codes in the memory? Looking for a possible trans code stored in the computer telling you what is wrong
Maybe this issue was already present in the van before you got the trans?
21.9 liter family
post #5 of 30 (permalink) Old 05-24-2018, 04:42 PM
79jasper's Avatar
Probably a wiring difference between a 98 e series and a 97 f series.
Try the pcm from the van.
79jasper is offline
post #6 of 30 (permalink) Old 05-24-2018, 10:28 PM
BigRed02
BigRed02's Avatar
Possible speed input issue??
Sent from my iPhone using Tapatalk Pro
2000 F350 CCLB 4x4 7.3L, 4R100, 6637, 4" MBRP turbo back
2000 F250 Red 4x4 Ext. Cab, 7.3L DI, ZF-6
2005 Ranger Dark Gray, FX4, 4 dr, 4.0 SOHC, 5r55e
2015 Ford Transit 3500, Dark Gray, HR EX, 3.5L ecoboost, 6 speed select shift
2011 Edge Limited Black, 3.5L
BigRed02 is offline
post #7 of 30 (permalink) Old 05-25-2018, 12:03 AM
79jasper's Avatar
Where's Mark kovalsky? Lol
79jasper is offline
post #8 of 30 (permalink) Old 05-25-2018, 03:07 AM
​ DieselDC's Avatar
Your 97 is an e04d with non pwm. The solenoid body has an orifice that bleeds off to control tc lockup. You’re trying to control a 4r100 with a pwm in a truck with eo4d electronics.
Stating all this, bts says the 4r100 pwm will work with the e04d b/c it can be turn to on/off. Switching with solenoid packs won’t change anything (u should really use one from a 97 and earlier) but a transgo #### kit and a new pump from a e04d will resolve your shifting issues.
At least that’s how I understand it.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #9 of 30 (permalink) Old 05-26-2018, 12:13 AM Thread Starter
redkw's Avatar
—————signature—————
I was told by Mark that since the van was a 98 it had nothing needed swapped. but he has not responded in awhile. I looked up the tag on the trans and it definetly is a 98 e350 trans. I just want my truck back. if this trans has to come out again its going to a shop
redkw is offline
post #10 of 30 (permalink) Old 05-26-2018, 12:17 AM Thread Starter
redkw's Avatar
I went from an auto to an auto.i have code p1748 and I cant get a straight answer on what that means. I do not have the van
redkw is offline
