05 6.0 excursion to common rail swap help - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By s10mike
post #1 of 6 (permalink) Old 05-20-2018, 01:29 AM Thread Starter
In the planning stages and looking for advice from those that have swapped a common rail into a 99-07 super duty/excursion.
Which company did you use for parts? How about wiring? I think I may mix and match, the companies do several things differently that I like. Looking for other input.
Has anyone used the 6.0 AC compressor instead of the dodge?
How about tuning, the dodge is out of an AUTO, the ex is getting converted to a zf6, do I need to have the ECM reprogrammed?
Any other advice from those who have done it? The donor is an 05 CR.
aspsu927 is offline
post #2 of 6 (permalink) Old 05-20-2018, 03:25 AM
79jasper's Avatar
Re: 05 6.0 excursion to common rail swap help
Well.... a common rail what?
Plenty out there. All of the duramaxs, 6.4 and 6.7 powerstrokes, 6.7 cummins, VW diesels, etc.
79jasper is offline
post #3 of 6 (permalink) Old 05-20-2018, 01:10 PM Thread Starter
Guess I didn't specify.... cummins. Although there are a few hints thrown in there (Dodge, dodge, and 05 CR should have narrowed it down) and I would venture to guess most people know what I meant.
aspsu927 is offline
post #4 of 6 (permalink) Old 05-20-2018, 01:47 PM
Master BS'er
jamiesaun's Avatar
My guess is that the pcm's are different between automatic and standard, but maybe a reflash will do it. I'm not sure.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 6 (permalink) Old 05-20-2018, 02:33 PM
s10mike's Avatar
whats a dodge?? lol
79jasper and HilhavenFarm like this.
s10mike is offline
post #6 of 6 (permalink) Old 05-28-2018, 06:44 AM
Scherf's Avatar
Garage
There are very easy ways to do this.... all depends on what you are wanting to save from your truck.... then you need to know what dodge motor you are wanting to put in, you can save your trans and just flash it for a dodge motor
2004 F-250 Lariat 6.0L, crew cab, 2006 motor swap, white w/ gray interior, SCT X4, 4'' down pipe with 5'' to a stack, 325/65-18 nitto terra grapplers, air rad intake, egr delete, studded and deleted, FASS System ([email protected]) with sump, 190/100% Swamps Diesel Injectors, atlas 80 PHP FICM, RCD rods, DDPM lifters, Turbo Lab of America turbo.
Scherf is offline
