E4od to 4r100 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 7 (permalink) Old 04-22-2018, 01:55 AM Thread Starter
redkw's Avatar
E4od to 4r100 swap
I thought i bought an e4od but it is a 4r100. I know you can swap them decently easy. Yet i do not know what a .090 orifice is and some people say you need things and others say you don't. Was hoping for some clarification. Maybe even just tell me everything. I have a 1997 f350 cclb 2wd dually. Thanks
1997 F350 XLT CCLB Dually 7.3 Powerstroke Automatic 2wd 3 inch straight thru muffler to 4 to 5 to 7 inch miter cut stacks
1997 F350 XLT CCLB SRW 7.3 Powerstroke Automatic 4x4 3 1/2 inch straight pipe
redkw is offline
post #2 of 7 (permalink) Old 04-22-2018, 11:52 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: E4od to 4r100 swap
Early '99 4R100s will swap in with NO problems. If it is a late '99 or newer 4R100 you need to change the orifice that controls the torque converter lockup clutch. If you don't change it the lockup will SLAM on every time. You'll hate it.
Go to THIS link. Near the bottom click on "Instructions." Then go to page 5, it shows you where the orifice is an how to change it.
heavydoc likes this.
Mark
The good thing about science is that it's true whether or not you believe in it. ― Neil deGrasse Tyson
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 04-23-2018, 02:57 PM Thread Starter
redkw's Avatar
i
It is a 98 e350 2wd diesel trans. I read you need to swap the tail housing and shift lever on the side of the trans and just leave the sensors alone. I really just need to know everything I need to swap because this is my daily and I hate driving the explorer. Thank you for the reply
redkw is offline
post #4 of 7 (permalink) Old 04-24-2018, 02:02 AM
That trans should work with NO changes.The tail housing and shift lever are the same between E-Series and F-Series.
Mark
post #5 of 7 (permalink) Old 04-24-2018, 09:44 PM Thread Starter
redkw's Avatar
Well it has a different shift lever on it definitely. I think the guy i bought it from said it was a replacement tranny at one point
redkw is offline
post #6 of 7 (permalink) Old 05-04-2018, 01:21 PM Thread Starter
redkw's Avatar
The shift lever is Definetly different. Im pretty sure the tail housing is too. Guy i bought it from said it was a new trans. If its a pwm torque converter can that be used? He gave me a torque converter, trans, and external tranny cooler
redkw is offline
post #7 of 7 (permalink) Old 05-04-2018, 08:00 PM Thread Starter
redkw's Avatar
I just looked up the tag on the 4r100. It came up with only 98 e350 tranny's. The shift lever is different. Pic is of 4r100
redkw is offline
