03 Excursion 6.0, 5R110 to early 04 CR - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-03-2017, 09:07 PM Thread Starter
wildbilly's Avatar
Thumbs up 03 Excursion 6.0, 5R110 to early 04 CR
So, I've got shopping list together of what I can afford and the other list is my build list of what I can't, but I'm simply able to build on my own. I'd be interested in wiring diagram from anyone who has built of similar years. I'm building a 04 Excursion 6.0 to a 03/04 5.9 CUmmins Common Rail sticking with my 5R110. I'm good with transmission, I just need to see the combining of the harness and the use of Ford PCM and the Cummins ECU. Also, if anyone has motor mount schematic I could sure one to compare to what I think will work. I would greatly appreciate the help with any and all you alls knowledge. Many thanks.
I know I didn't have the opportunity to get through all of later forums, but the ones I did find that applied where from 2014-15.
Hunting, Fishing, Diesels and Loven' Every Day...Sounds like that's a country song!
wildbilly is offline
post #2 of 5 (permalink) Old 10-04-2017, 12:18 AM
Moderator
Sbluke55's Avatar
Re: 03 Excursion 6.0, 5R110 to early 04 CR
There is currently two people doing this exact swap over on powerstroke.org. one is an excursion too.
01 f-250, Standard
Sbluke55 is offline
post #3 of 5 (permalink) Old 10-04-2017, 01:19 PM Thread Starter
wildbilly's Avatar
Than you, I'll check it out.
post #4 of 5 (permalink) Old 10-04-2017, 01:48 PM
Moderator
Sbluke55's Avatar
I guess i should of told you their names. One is junior125 and the other is master_chase. If I find one of the threads I'll link it here.
01 f-250, Standard
Sbluke55 is offline
post #5 of 5 (permalink) Old 10-04-2017, 01:59 PM
410customs's Avatar
we could sure use one or two of those threads over here!!!
hint hint
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
