97 7.3 swap into 2000 5.4 f250 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-17-2017, 12:55 PM Thread Starter
Hello Everyone,
I have been debating on the cummins swap or 7.3. I've been doing plenty of research but I couldn't find much on the 1997 obs 7.3 being swamped in a 2000 f250 with a 5.4. Is the swap straight forward or do I need to fab a few things? I'm assuming I need to replace dash harness and my trans. Any info would be greatly appreciated! I found a 97 f250 as a parts truck, I was going to buy it as it's priced fairly cheap.
jruz14 is offline
post #2 of 4 (permalink) Old 08-17-2017, 01:07 PM
410customs's Avatar
Re: 97 7.3 swap into 2000 5.4 f250
no
You want to use a 99-03 7.3 for your superduty, not an OBS 7.3. Several advantages to the superduty 7.3 as a donor and will make your life much much easier.
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 4 (permalink) Old 08-17-2017, 01:49 PM Thread Starter
Okay thanks for the info. Could I use my transfer case?
jruz14 is offline
post #4 of 4 (permalink) Old 08-17-2017, 02:08 PM
410customs's Avatar
no the 5.4 uses a smaller t case you will want the one from the diesel donor IMO
21.9 liter family
