90s 7.3 powerstroke swap into a 78 f150 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Sbluke55
  • 1 Post By jamiesaun
post #1 of 10 (permalink) Old 06-20-2017, 01:08 AM Thread Starter
Hey guys really been thinking about this for some time and would like to get information on the subject I would like to use a 95-97 7.3 powerstroke motor with the e4od trans and transfer case and drop it into a 1978 f150 regular cab short box 4x4 that will be lifted and some points I want to get across are. No I'm not worried about fuel economy this is not a Dailey driver it will be a toy and also I'm never going to pull or have a load on this truck strictly toy that being said could I keep the half ton axles that r on the truck now and what kind of Wiring problems would I run into thanks.
Mr.Stroker is offline
post #2 of 10 (permalink) Old 06-20-2017, 01:21 AM
Native Texan
masakimm's Avatar
Garage
Re: 90s 7.3 powerstroke swap into a 78 f150
Well you would have to use most of the wiring from the 7.3l and of course the computers. the axles would handle it but the front springs and mounts will probably need some beefing up to support the weight. If the rear is a 9 inch then you can beef it up to handle the power. It will definitely be a project And I look forward to following it.
Upgrades:
masakimm is offline
post #3 of 10 (permalink) Old 06-20-2017, 01:54 AM
Master BS'er
jamiesaun's Avatar
Sounds pretty interesting.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #4 of 10 (permalink) Old 06-20-2017, 01:55 AM Thread Starter
Yes a Dana 44 Straight axle front and 9 in rear end r what's in it thanks for the input I would like to do it but not a sure thing yet
post #5 of 10 (permalink) Old 06-20-2017, 02:15 AM
Native Texan
masakimm's Avatar
Garage
I was going to put one in a 76 motorhome but then I got my truck and decided I wanted it more the the motorhome. Well I will look forward to it if you decide to do it.
Upgrades:
masakimm is offline
post #6 of 10 (permalink) Old 06-20-2017, 02:50 AM
Project Shamu
Lt.Dan's Avatar
If you're running the E4OD then you will have to run the sterling 10.25 or 10.5" axle, simply because your 9" doesn't have the vehicle speed sensor.
So plan on changing the rear axle.
That being said, you dont want 8 lug rear and 5 lug front, so plan on changing the front axle to match.
Or you could go manual zf5 or zf6 and the speed sensor is irrelevant (i think)
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #7 of 10 (permalink) Old 06-20-2017, 03:15 AM
Moderator
Sbluke55's Avatar
Just buy a parts truck with everything. Swap the axles and everything over. You can cut the main harness down to the bare bones and you really just need a few wires. @markfuga has done it. He is here and on the army. I personally think setting the cab and bed on to a 97 frame would be easiest.
410customs likes this.
01 f-250, Standard
Sbluke55 is offline
post #8 of 10 (permalink) Old 06-20-2017, 12:26 PM
410customs's Avatar
I agree with Sbluke, I was just looking at a 1973 F250 7.3 8 lug truck yesterday which is basically a 73 body on a lightly modified 97 frame...he even used the 97 dash and it fits like stock this is the easiest approach IMO the body dimensions and sizes all appear to be real similar up to 1997 making it easier to use old bodies on newer frames
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #9 of 10 (permalink) Old 06-21-2017, 02:15 AM Thread Starter
Thanks for the info I also thought about this to I've swaped a 78 onto a 87 Broncos frame before should be the same concept
post #10 of 10 (permalink) Old 06-21-2017, 02:49 AM
Master BS'er
jamiesaun's Avatar
Well there ya go bro! Nothin to it but to do it.
Lt.Dan likes this.
Brother James
