2003 ford v10 to 6.0 conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-20-2017, 11:17 PM Thread Starter
I want to do a 6.0 conversion, i got some info already, just want to get some more. Motor mounts for a 2003 6.0 do they bolt up to the frame? Another the ficm and pcm does that line up in the truck and does it have to specially for the motor? Any help? Thanks
Maximracer27 is offline
post #2 of 3 (permalink) Old 01-21-2017, 02:34 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 2003 ford v10 to 6.0 conversion
A V10 PCM won't run a diesel. And a V10 doesn't even have a FICM.
You didn't ask, but the transmission will work, but you'll need an aftermarket controller. From the factory there was no such thing as a 6.0L/4R100 combination. Or you could get a 5R110W trans that belongs with the 6.0L.
Mark
Mark Kovalsky is offline
post #3 of 3 (permalink) Old 01-25-2017, 05:44 PM
410customs's Avatar
or do a 7.3
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
